Thread: Sticky liquid seeping from side of Spa filter
    Ithaca, NY
    13
    I have a bizarre leak seeping from the side of the filter of the Spa I operate. The filter is a Neptune-Benson model # 36CCFG-2. I have sent pictures to the company that installed it and I am waiting to hear back from them to see if they have any idea what is going on but I am curious if anyone here has encountered a similar problem. Basically, there is a sticky, white textured liquid seeping out of the side of the filter; the leak is not near any valves and the liquid smells similar to silicone caulk. It dries into a dark greenish blue substance. There is no visible hole or scratch where the liquid is seeping (see attached pictures).
    Re: Sticky liquid seeping from side of Spa filter
    If it smells like silicone it is likely a sealer they used . Why it would be coming out is beyond me. That reminds me there sould be a x-file catagory for posting stuff like this and other mysteries. I am sure someone will be along shortly that may be able to solve this mystery.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
