Results 1 to 10 of 10
Thread: Newbie Question
    Feb 2010
    South Alabama
    27
    Newbie Question
    I am so glad to have found this forum. I just put in a pool last summer and with your help, I cleared my cloudy pool caused by my Pool School Guy!! I really love this forum. And please know that I am VERY new to pool chemistry knowledge!!!
    First (see I read the rules) here are my numbers:
    Free Chlorine 2.6 ppm
    Combined chlorine .2 ppm
    PH 7.6
    CH 200 ppm
    Alkalinity 110 ppm
    CYA 40 ppm (I think.....hard to see when the dot disappears!)
    My SWG is set on 70% though and I would like to lower it.
    Should I turn my SWG down to say 60% right after I add Stabilizer or wait a day? I don't want my chlorine to go up much more, but I would think that by adding stabilizer it might.
    Thanks guys,
    Madeline
    10,620 gallons/IG/plaster
    SWG
    Cartridge Filter
    Ozonator (only because PB wanted my business!)
    Pump 1.5 HP (2-speed)
    Mar 2009
    Macon Ga
    77
    Re: Newbie Question
    Hi Madeline
    You do want your CYA between 70 or 80 and I have found that 80 is better for my pool. You also want your FC a little higher. I would leave the SWG where it is at now unitl you can get to a level of 4 FC and the CYA is where you want it and then tweet it back.
    Ken
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    Feb 2010
    South Alabama
    27
    Re: Newbie Question
    Thanks Ken! I was going by a test I had done at Ace Hardware and they said the FC should be between 1-3, but pool school says 3-5. I'll have to change it on my tests!
    And I guess it's okay to leave the SWG at 70%. I thought that was a little high.
    SWG
    Cartridge Filter
    Feb 2008
    Denton, TX
    5,061
    Re: Newbie Question
    Welcome Madeline. I have always loved that name!
    As kenmccall mentioned, SWCG pools tend to do better with a higher CYA as this protects the FC from being lost to the sun and as a result, your SWCG cell doesn't have to work so hard.
    The amount of FC that you should maintain as a residual in your pool directly relates to the amount of CYA dissolved in the water. The Chlorine CYA Chart allows you to see where you should target your FC, based on the amount of CYA you have. You will note that we have only included CYA levels of 60, 70, and 80 for SWCG pools on the chart, because these are the typical levels we have found work best for salt pools. As it stands, your FC is too low for your CYA. The minimum FC that you should ever have with a CYA of 40 is 3 ppm.
    I would go ahead and peruse the Pool School articles and get familiar with what is involved with things. I would also get you some bleach and add enough to get the FC up to 4 and keep it there. You should also get a little more CYA in there to get you to at least 60. Once you get those things in line, you won't have to have the SWCG set so high and things will level off a bit.
    You should also go ahead and get you a solid test kit. The TF-100 is excellent (link in my sig line).
    Use the Pool Calculator (link also in my sig line) to calculate the dosages for the vairous chemicals you may have to add. Bookmark it in your browser. The Pool Calculator is your friend.
    Feb 2010
    South Alabama
    27
    Re: Newbie Question
    Thanks.......I used to hate my name as a kid!!
    I just put some stabilizer in, so should I add bleach now too?
    I do have the T-100 test kit, although figuring out when the black dot disappears is difficult!
    Thanks so much for the tips!!
    Madeline
    SWG
    Cartridge Filter
    Feb 2008
    Denton, TX
    5,061
    Re: Newbie Question
    Quote Originally Posted by Maddie
    Yes, go ahead and add it.
    Try this link for an example.
    http://www.taylortechnologies.com/Chemi ... ntentID=36
    It's best to take the reading on a sunny day. Sit with the sun to your back where your body shades the sample and start adding drops. As soon as the dot completely goes away, take your reading.
    Madeline
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Newbie Question
    I will also add on the CYA test that I was so glad to know I could pour the solution back into the mixing bottle a few times and repeat the disappearing black dot test and see if 3 or 4 times it disappeared about the same level.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Feb 2008
    Denton, TX
    5,061
    Re: Newbie Question
    Quote Originally Posted by poolgirl22
    Excellent point!
    Feb 2010
    South Alabama
    27
    Re: Newbie Question
    Thanks ModSquad.....I will do that when I test it tomorrow!!
    And poolgirl......that IS a great tip. I never thought about that!!
    SWG
    Cartridge Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Newbie Question
    Hi Maddie - welcome to TFP
    That old "1-3" recommendation comes from old school thought of pools with no CYA in the water. Now that we understand the CYA/Chlorine relationship that recommendation is a bad one for pools with CYA higher than 20 (which most are) - but many pool store and testing places still quote it.
