Thread: Low Pressure Switch
    Low Pressure Switch
    Hi, I have a problem but not all the time, I have a solar heater system, I have a relief cap on one end of the collecters what happens is it blows off sometimes and the pump runs about 4-5 inches of water out. I'm looking for a way to have the pump shut off if it looses pressure, Does anyone have anything in mind that will shut my pump off to prevent the loss of all my water? Where might I find it?
    Thank You, Mike
    Above Ground Pool - 13,500 Gallons - Sand Filter - 2.5 HP 2 Speed Pump
    Intex 8110 SWG - Leslie's Chlorine FAS-DPD Service Test Kit
    (Previous Owners used Baquacil...We used it for 2 summers and are TROUBLE FREE since 5/27/10!!!)
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Low Pressure Switch
    Adjustable pressure setting, 25 Amp capacity, can switch on or off. Designed for spa use.
    http://www.amazon.com/gp/product/B003BG ... sw_em_r_dp
    Quote Originally Posted by Ohm_Boy
    Thanks I see if I can get this device to work, Thanks again, Mike
