Thread: Ready for help if anyone is willing
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    My tf-100 test kit came today, so now I am ready to start adding what is need to the pool.
    If anyone is willing to walk me through the next steps I would appreciate it. We did get the filter and pump up and running last night. Here are my stats:
    New ag pool, city water, fresh fill
    Water temp. 54
    Cl- 0
    Ph- 7.2
    T Alkalinity- 40
    Would the first step be putting cya in? If I am reading the pool cal. right I need to add 79 oz of cya for a target of 30. This is done by putting it in a sock or stocking and hanging it in front of the skimmer opening? With such a large amount, would you do it is smaller amounts until you use all that is needed?
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    22,539
    Re: Ready for help if anyone is willing
    First thing is to get some chlorine in there. About 3½ quarts of 6% will get you started.
    Then add your CYA in a sock about half of it at a time.
    Then, though your pH is fine I'd bump it up a little bit.
    You're probably going to bump your TA up a little too.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    Thanks, will go out and add the chlorine now.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Raise your TA to about 80 and after a few hours retest the PH before you adjust it more...
