Results 1 to 8 of 8
Thread: Shelf life o f CYA Reagent
    Jul 2009
    Fort Wayne, IN
    392
    I just opened my pool and found that I ran out of CYA Reagent at the end of the season last year. I need to order more, but find I really ran through alot of it last year when I started BBB. Now I'm a seasoned veteran (already up and running in only 5 days!!!!)
    Just visited the order site and found that it is sold in 8 oz bottles. Can I buy two to save on shipping, or will it go 'bad' before I'm able to use it all? Basically, what's the shelf life?
    thanks,
    theresa
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    Re: Shelf life o fCYA Reagent
    The CYA reagent is good for several years as long as it doesn't freeze or get left in the sun for a long time.
    Hi all,
    Where can I re-order the re-agents for my TFP test kit? Thanks!
    John
    17.5K IG Pool with Spa spillover and fountain, Plaster Finish, Purex Triton CC420 Cartridge Filter, Pentair Intelliflo XF VS motor, Laars LX GasHeater, Polaris 360
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Plankton
    Hi all,
    John
    http://tftestkits.net/TFTestkits-Refills-c11/
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Shelf life o f CYA Reagent
    Quote Originally Posted by 8corneflakes
    thanks,
    theresa
    I saw your username and remembered your thread from last summer.
    Then I saw your sig and nearly ROFL
    You're done SLAMing when:
    Thanks Richard!
    Oct 2007
    Cedar Hill, TN
    251
    Good to know.
    For some reason I purchased a 16oz bottle last year.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    May 2009
    Austin, Texas
    77
    Could you be more specific than "several years"? (Dictionary says "more than 2, fewer than many.")
    I seem to be losing CYA faster than anything, but bought my R-0013 reagent 3 years ago. Is that probably my problem?
    Mike
    25k IG w/ Pebble Sheen +8' diameter spa w/spillway w/ Hayward ProLogic +T-CELL-15 SWCG
    Cartridge Filter and Gas Heater on Hayward Pump SPX3215X20Z1PE (w/ 2.00 HP, 1.10 SF motor)
    +separate waterfall on Hayward Pump SPX3210Z1PE (w/ 1.00 HP, 1.25 SF motor)
