Results 1 to 9 of 9
Thread: BBB version of stabilizer/Cyanuric Acid?
    With the pool drained, I know I have to start over on chemicals. My chlorine levels are at shock currently (and leaking with the rest of the pool water), so I know with the leak team fixing my issue tomorrow morning, I need to add stabilizer soon. The pool store's answer is to sell me 4 bags of stabilizer at over $75! Is there a BBB version of stabilizer? Some common kitchen version of Cyanuric Acid that I can get from grape fruits or Tide or match sticks or used underwear or something?
    I looked in pool school and didn't see anything there about Cyanuric Acid in BBB.
    Denis
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: BBB version of stabilizer/Cyanuric Acid?
    walmart carries HTH Stabilizer/conditioner for about $16 for 4lbs and should raise your CYA by 40ppm
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by dmanb2b
    If you go that route, check and make sure that it is 100% Cyranuic Acid. I looked at some stuff at home depot or lowes cant remember, but it was only 96% and 4% other. So not sure if that 4% will mean anything but did not want to take a chance.
    I even bought a 4.5 lbs of stablizer at the pool store for 19.99 and this was from warehouse pool supply, so not sure if they are everywhere.
    Here is some info about the products they carry at walmart. Looks like it has some good info on it.
    http://www.archchemicals.com/Fed/HTH/
    On the link above they also have a live chat option.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup...HTH is 96%...worked fine...96% is fine to use...Obviously 100% would be better
    Aug 2009
    North Central Texas
    1,358
    96% is fine to use. I actually prefer the HTH brand from Walmart as it dissipates from the stocking in front of return much faster than any other brand I've ever used, especially if you massage the stocking a few times. It, also, seems to dissolve into the water much faster. (Be wary of all the other Walmart chemicals as many have copper in them. I prefer their metal sequestrate, as it seems to do some work on the scale. The bottle states to use this product with the HTH chlorine content sanitizers. That's because of the copper content which can eventually leave copper staining on pool walls and floors.) You may want to put in a little less than called for as I just recently got higher CYA levels, in two pools, than what I measured for. It wasn't drastically higher but, in both cases, I used several lbs less than pool calculator called for, to start. I think, also, since it seems to dissolve into water faster you can get a reading in a few days instead of a week. For both pools the pump was run 24/7. (In both cases we could consider pool volume inaccuracy, but the first pool calculated volume is pretty close as determined by results from adding other chems but I may have calculated the second pool volume a little high but it shouldn't be off much. Initial pool calculator called for 4 lbs more than I added and it went from 0 to 50 in four days. Also to consider, for the second pool, that the 0 reading of CYA was actually somewhere between 0-20 as it is hard to get a really close measurement with the CYA test.)
    If you want to massage the stocking(s), in front of return, for 30 seconds or so, several times the first day, you can actually get it all into the water the first day. It will come out of the stocking as a very, very fine powder and disappear quickly into the water. I've taken reading three days after stockings have emptied and gotten accurate readings.
    First pool I used heavy women's tights which worked great. Second used regular women's knee high (I've done the knee high and tights more than once) and the hose does tend to run letting some granules out rather than only fine powder when you massage.
    For the second pool I put two lbs of CYA in four stockings, in front of four returns. This is my friend's pool so I couldn't be there to massage the stockings. The stockings are tied to bricks sitting on edge of pool. My friend knocked one brick and stocking into the pool. When I went back over the next day three of the stockings were almost emptied. The one that fell in looked as it did the day I put them in. I massaged that bag a total of 3 minutes and got all of it emptied.
    I have pretty delicate skin. I massage the bags without gloves on and never seem to have any problems with my skin. I do rinse my hands off and put lotion on afterwards.
    Edit - As the metal sequestrate at Walmart is some much cheaper than others I've used I do tend to use more of it. I used it all winter after an AA treatment. That may be why is has continued to lift the scale.)
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Butterfly's Avatar
    South Carolina
    10,045
    Wonder how many pounds of CYA the pool store is planning for your pool
    As said, about 4 lbs should get you to about 40 CYA and 5 lbs should get you to about 50. Florida sun and all that.
    You can also check your big box stores (if wallyworld is out) like HD and Lowes.
    Last month we bought 6lbs of 100% CYA from the local pool store for $27.
    You're done SLAMing when:
    Aug 2009
    North Central Texas
    1,358
    As of last week, the Sta/Cond, at my Walley's was $14.97 for four lbs. Leslie's was running a special on theirs, 8 lbs. for $29. I sent my friend to Walley's because I wanted to use the HTH (for one dollar more) and she needed Walley's bleach. AND I wanted to keep her out of the pool store and away from any sales pressure to buy pool store chems. BTW.... our Leslie's doesn't sell liquid 12% chlorine.
    gg=alice
    Quote Originally Posted by geekgranny
    Neither does our Pinch A Penny. It's only 10.5%.
    Clearwater, Florida
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by denisbaldwin
    Darn. I keep hearing about Pinch A Penny. I don't think we have those here but I'm going to check on it.
    gg=alice
