Results 1 to 8 of 8
Thread: Vacuuminga pool?
    Vacuuminga pool?
    When Vacuuming your pool do you leave the sand filter on filter, then backwash when done Vacuuming?
    Or do you put sand filter to waste when Vacuuming?
    I always put to waste while Vacuuming, i never thought about it till now and thought i would ask.
    K HOLMES
    23 X 45 GUNNITE
    OWNER/BUILDER
    22,550
    Re: Vacuuminga pool?
    I usually leave mine on filter unless I'm cleaning a bunch of dirt or oak worms. Vacumming to waste uses a lot more water than vacuuming on filter and then backwashing, in my experience anyway. YMMV
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    If you have a lot of stuff to vacuum out I would switch to waste, if just a little spot cleaning I leave on filter and backwash when the pressure reaches my backwash level. If you leave on filter and have a lot to clean out the filter pressure will rise rapidly and you will have to backwash frequently. Experience will tell you which uses the least water.
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    Dec 2009
    Central Massachusetts
    2,690
    It depends on how much "stuff" I'm trying to vacuum out of the pool. Most of the time, I vacuum with it set to "filter" ~90% of the time). I use this setting for my routine once or twice a week vacuum. Once in awhile, I will vacuum to waste. If there is unusually heavy debris I dont want going thru the filter, I'll use that setting. I use a skimmer sock too, so it catches a lot of stuff there as well. I dont backwash after every vacuum either. For me, my base filter pressure runs around 10 psi. When it hits 16-17, i'll backwash.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2007
    New Jersey
    653
    It depends. In my old pool, 40K gal and a 3/4hp pump, I would always vacuum to waste. I needed the better performance and I didn't lose that much water. In my new pool, 28k gal and a 1.5hp pump with all 2" plumbing, I lose several inches of water if I vacuum to waste and I can barely move the vac head. So I always vacuum to filter. I only backwash when I reach my pressure limit. The pump trap gets all the big stuff.
    So try it both ways and see what works for you.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    If you have a lot of large debris an inline leaf/debris canister will be your filter's best friend. They install about 4-5' from the skimmer/vac connecton and can really reduce the amount of times you have to backwash and/or vac to waste - obviously they are not intended to catch small partical waste like algae, but if it is leaves and large debris, they really help.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Thanks for everyone's replies. I didn't know if there was a correct way to vacuum or not.
    I have always vacuum to waste.
    Since i do most of the vacuuming in the morning , I go out before the pump kicks on and all of the debris is in the center, Vacuum it up and hit anything that i can see.
    Then repeat in a few days.
    K HOLMES
    23 X 45 GUNNITE
    OWNER/BUILDER
    22,550
    The correct way to vacuum is to do what works for you. If I could get out every day and it all be in a neat pile I'd probably vacuum to waste all the time too.
    My junk's never in a neat pile, it's all over and since I'm responsible for getting the GS to baseball games and practice I only get to vacuum once or twice a week.
