Thread: Do I need a pool man??
    I just noticed that the little pump next to my sand filter has more air bubbles than usual when the pump is filtering. I've got plenty of water in the pool and my skimmer basket is clean. I've also noticed that my return jets are surging a little. I can't figure out the problem. There is one thing that's an issue, but I don't know if it's contributing to my problem...the little valve that you usually loosen to allow water to spew (after turning the pump to filter after backwashing) will not screw all the way in when it has the little o-ring on the end?? If i take the tiny o-ring off, it will screw all the way in and water won't spew when the pump is filtering...again, I don't know if this is contributing to my problem or not. Any advice would be appreciated.
    Alan
    22,553
    Re: Do I need a pool man??
    Is your pump strainer basket clean as well?
    Did you lube the pump strainer basket lid last time you put it back on?
    Bubbles in the pump basket is a good indication of an air leak.
    What do you use to lube the basket? What are the likely places for an air leak?
    Alan
    22,553
    Use silicon pool lube to lube the o-ring on the basket lid.
    Common places to have air leaks are the pump basket lid, skimmer creating a vortex and sucking air, pump basket drain plug, plumbing leak.
    I did find where water was running down a couple of places from the "neck" of the equipment on top of the sand filter (the equipment that houses the valve that switches from backwash to rinse, etc.) One of the places was actually bubbling a little bit. Assuming that is my problem, is there anything i can put around the neck to seal the leak?
    Alan
    22,553
    That , while it needs fixing, is on the discharge side of the pump and therefore wouldn't cause air in the pump basket.
