Thread: Happy Mother's Day
    Feb 2008
    Flower Mound, TX
    Happy Mother's Day
    Happy Mother's Day to all our pool managing moms out there. You're the greatest!
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    jmack1159's Avatar
    Apr 2010
    Re: Happy Mother's Day
    Thanks so much! Hope you have a great day as well.
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    Aug 2009
    North Central Texas
    Cheers and hugs to all Moms.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Butterfly's Avatar
    South Carolina
    Thanks Craig
    And, cheers to all moms
    You're done SLAMing when:
    NWMNMom's Avatar
    Waaay NW MN
    My wonderful hubby and sons are building a pool shed for me today and started working on getting the solar panels up, getting things prepared for the new liner, etc. I'm loving it! The sun is shining and it's going to be a great day for Mothers Day! Happy Mothers Day to all out there!
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
