Thread: status message "check flow"
    I have intellichlor IC40 ECG and getting status message, "check flow/PCB" on easy touch panel
    under diagnostic, chlorinator. All lights are green
    17,000 gallons
    sand filter, IG, vinyl
    22,551
    Re: status message "check flow"
    Sounds like you have a bad or blocked flow switch. The first thing I'd do is check the connections to it though. A bad connection will cause the unit not to see the flow switch signal.
    Dec 2009
    Central Massachusetts
    2,690
    It's not a connecction nor a bad flow switch, most likely. I have the same issue with mine on occasion. It's a glitch/error in the hardware/firmware for some versions. If you do a search, this same issue has come up before and discussed on TFP. If all the lights are green including the cell and flow light, it's making chlorine. The error message, in most cases, can be ignored. You can contact Pentair and see what they say. It wont be the first time they have heard the complaint I assure you. I believe Pentair originally blamed it on high phosphates, but so many people had the issue they finally said it was a firmware problem. I need to call myself and see what they say. As I said above, if the proper lights are green, it's making chlorine. I checked mine by measuring the FC at 10 pm. I set the IC-40 to run 100% overnight and the next morning I had an FC increase, so the error is purely a glitch that doesnt affect operation. Its' just annoying to see.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
