Results 1 to 14 of 14
Thread: Couple of questions on the Liquidator...
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    I have a Hayward in line chlorinator which uses the chlorine pucks. It is plumbed so that one line is tapped at the pump exit, and the other is tapped just after the heater (my equipment order is pump, filter, heater). Can I use these existing lines, or does the Liquidator need to be plumbed at the pump inlet/suction?
    I assume that the chlorine/water mixture is introduced prior to the equipment (ie. pump, filter, and heater). Is there any concern over this, or is it such a low concentration that it doesn't matter?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    30,432
    Re: Couple of questions on the Liquidator...
    The liquidator relies on the low pressure that exists on the suction side of the pump to get the chlorine into the system, so you could perhaps use one of the pressure side openings for the LQ and then the pump strainer basket drain for the suction side.
    22,553
    As Dave said, it needs a connection at the suction and discharge of the pump to work. The discharge connection is used to fill the LQ and the suction connection is used to feed the chlorine into the system. There's no concern with adding the solution before the equipment.
    flyboy320's Avatar
    Jul 2009
    216
    Man you guys are fast
    Thanks for the help....Oh, and with the larger 3/8 line mod, do most people find it works fairly well now?
    22,553
    It works just ok as it comes but with the 3/8" mod I can peg the flow meter out! I believe I could maintain shock level with the LQ now. I recommend to anyone to go ahead and do the 3/8" line mod even before the ever install the unit the first time.
    22,553
    One note: when doing the mod it's not necessary to drill the holes in the float valve shrouds. Doing so opens you uip to possibly damaging the float valves. Which has been reported happening a few times. It won't increase the flow because the limiting factor is the nozzle which you can't (and don't need to) change.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by flyboy320
    I tested my water by opening the union on the pump outlet enough to get a sample. It was only 2 or 3ppm higher than the pool water.
    Feb 2008
    Milford, CT
    337
    Agreed!! I learned it the hard way.
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    flyboy320's Avatar
    Jul 2009
    216
    As far as using the pump strainer basket drain, can you buy a part that will fit in and replace the drain plug so you don't have to drill out the drain plug, and be able to use the drain plug at a later date if needed?
    Maybe something like this. Not that that is the right piece, but maybe something like it might work?
    30,432
    To my knowledge, all those drain plugs are 1/4" NPT so that is the precise fitting that'll work if you use 3/8 hose.
    flyboy320's Avatar
    Jul 2009
    216
    Thanks again guys.
    I am going to order some 3/8 line from US Plastics along with the valves and fitting from the upgrade thread. How much line should I order (or how much comes with the liquidator)?
    Is this the right line to order? I see there are two types, one with 1/2" OD or a 5/8" OD.
    22,553
    That is the right stuff. You really don't need the thick walled stuff. I didn't order the UV resistant stuff either. Partially because I just figured I replace it in a couple of years and because my equipment is under a shed. Here's what I bought.
    I odered 10' and had to be careful about routing in order to have enough. I wish I had ordered more.
    flyboy320's Avatar
    Jul 2009
    216
    Great, thanks for everyone's help...
    Feb 2008
    Milford, CT
    337
    I actually got the required tubing from Lowes. It might not be tygon tubing, but its black (I hated looking at cloudy tubing), the correct diameter for the mod, and CHEAP. Something like 20 cents/ft. I wanted 20' (I have my LQ in a nearby storage shed), the roll probably had 35' left, Lowes guy just gave it to me for the price of the 20' I wanted....score!
