Thread: leak in drain body
    leak in drain body
    Anybody use plain silicone to fix a small leak in bottom of a pool?
    There is a small gap between the plaster ring and the drain body that is letting water drain between the two, Small slow leak. Just wondering if a bead of silicone will do the trick, im pretty sure it will work but for how long?
    22,000 Gallon inground gunite
    Pentair Intelliflo pump
    Pentair tr-100 sand filter
    Pentair Minimax NT 400,000 BTU heater
    AquaRite chlorine generator
    AquaPC-On Point chemical controller
    30,419
    Re: leak in drain body
    I don't think you'll be able to get a bond underwater.
    pool is drained and dry.
    It would be better to use a two part pool putty. The silicone will just be washed away after a while.
