Thread: Goldline AquaRite 40K vs 20K
    I found an online seller that appears to have a great price on the 20K system with a 15-cell, which is the largest they make. Their 40K system also comes with the 15-cell; however, there is a $150 price difference.
    So what wouldn't the smaller controller have that the larger would? My pool is only approximately 15K gallons, and I've read that I want to oversize my SWG. But obviously, I want to use my money wisely! If they both come with the larger 15-cell, why should I invest the extra $150? It's the cell that's creates the chlorine, correct?
    Thank you for your time and assistance!
    15,000 gallons in-ground kidney shaped, 15' x 30' Vinyl liner 3.5' to 6.5' deep
    1 ½ hp Pentair Challenger pump w/ Intermatic timer (220V)
    Pentair Sand Dollar Top-Mount Sand filter SD-60
    Pool construction began 3/15/10. Finished 4/03/10.
    BBB Method with Salt (No SWG, possibly next year)
    TFTestkits TF-100 XL & Lamotte Borate test strips
    Add borax to improve feel & prevent algae
    The Pool Calculator
    Jul 2007
    Brisbane, Australia
    Re: Goldline AquaRite 40K vs 20K
    it's also the power that you apply to the cell, that matters
    however if different power supplies are used to drive the same cell, most likely you won't get more life out of it, so it's kinda pointless getting larger unit. the only benefit you will get - ability to increase chlorine production (at the expense of cell life)
    NWMNMom's Avatar
    Waaay NW MN
    As far as I have seen, the controllers are the same on the standard Aqua Rite systems and the cell is the only difference between the 20K and 40K units, BUT are you sure one isn't an Aqua Rite Plus or another version? One of them may be the version with the timer built in or some other type of automation - the standard Aqua Rite Controller does not have a timer on it, you hard wire it to your timer system.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    I suspect that it is a typo in the ad, and the less expensive unit actually comes with the 20K cell.
