Thread: Pump Question
    Pump Question
    I am two weeks out of my pool build being started. I am having a little change in heart about some features but before I decide to through in something new I want to understand some of the additional cost. As you can see from my tag line the pool is 13k and we will be using 2" PVC. My question is as follows, my plan the whole time was to put in a SR Smith Turbo Twister, and a Polaris 280 I am now thinking of adding 3 Pentair Deck Jets. Can my 3/4 HP Whisperflo do this or do I need to upgrade? If I need to upgrade what do you suggest?
    11K gal, in-ground 15'x33' San Juan Fiberglass, Pentair Whisperflo 3/4 hp pump, Pentair Clean & Clear Plus Filter CCP320, Pentair Inteliclor 40 SWG,
    mas985's Avatar
    Pleasanton, CA
    11,473
    Re: Pump Question
    When you have a lot of different features and not sure what is needed to run everything, the Intelliflo can be an ideal solution. It can be optimized for each function. Not only that but when the pump is just circulation the water, the most energy efficient setting can be used.
    Mark
