Thread: concrete pool deck paint and sikaflex
    Aug 2009
    SF Bay Area (Lamorinda), CA
    I assume all concrete pool deck paints are not created equal - anyone want to post the good/bad/ugly about ones they've worked with.
    Also replacing the expansion seal is in our future - what places have the best prices on Sikaflex, it's not a common item in any of our local hardware stores.
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    Re: concrete pool deck paint and sikaflex
    I buy the SikaFlex SL at Home Depot. It can be found over in the masonry section. The quart (?) tube runs about $12.00 and it goes pretty far (the info on "coverage" on the tube is pretty accurate). Really easy to use, even if you haven't done it before, and much cheaper than having the 2 part mastic done by someone. Post back if you need direction on how to do the job (I know it is on here somewhere already also).
    Pool deck paint requires great prep. Paint isn't my favorite, and you will have to redo it from time to time, so make sure you are ready for all that is required before you commit!
