Thread: "Germicidal" Clorox?
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I was at Home Depot the other day and saw Clorox brand "germicidal" bleach. It has a higher chlorine percentage than regular clorox(6.15 vs. 6.0) It doesn't say that it contains anything else, and it's also a bit cheaper, too! Has anyone used this kind of bleach before?
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: "Germicidal" Clorox?
    I think that I would use it. MSDS here
    Yes, that is totally fine. The Clorox "germicidal" labeling is for their "commercial" bleach. In a few really minor ways it is actually better, since it has fewer additives.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I'd use it. Lots of "commercial" products are cheaper than the consumer version, and work better, too. They just don't have the glossy packaging. We used to get commercial Tide detergent in 40 pound boxes to clean the shop floor. Cut grease great, no perfumes, hardly any suds.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Cool, I'll give it a try, I just picked up 4 jugs so I should be all set for a while
