Results 1 to 12 of 12
Thread: Newbie and of course a question
    Ok, gang glad to be here. I have a 13500 in grown pool. I have lived here for 5 years and kept the mom and pop pool service who now charge 185/month. I watched their men check the pool recently and this consisted of skimming with a basket, no vacuuming and using a dropper bottle into the pool to decide to put two tri-chlor tablets in the skimmer.
    I have been reading everything here and decided to let them go and take it on myself. I got some test strips and chlorox and baking soda and over a week it already looks better.
    I just ordered the TLF-100 test kit so I should shortly get better info.
    My main basic question is this. I have two pumps but only one is routed through a skimmer. One is an extra for swim jets. Since I have lived here the skimmer pump has run 24 hours 7 days per week. From what I have read here not everyone runs their pumps 24 hours a day. I live in central Mississippi so it is hot and muggy. After I get the chemistry straighten out should I limit the amount of time the pool pump runs?
    I appreciate the site and have learned ALOT.
    MK
    13500 gal in ground. 1.5 HP Hayward pump. Triton Sand Filter. TFP and Pool Calculator. LQ C-201.
    22,553
    Re: Newbie and of course a question
    Welcome to TFP MK
    Tell us a little more about your equipment and even post some pics of it if you can.
    It seems reasonable that you could run your pump less than 24 hours a day and once you get your levels straightened out we can help you decide how much (if any) you can reduce your run time.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi MK and welcome to the forum
    .....thinking of all the things you can buy with $185 per month.....
    And, you have already ordered the TF100 kit!
    Trust us, it is not difficult to maintain your water chemistry with the proper testing kit. I think you will be pleasantly suprised
    You can add your pool and equipment specs in your signature so that they always appear when you post.
    Go to User Control Panel (upper left under TFP logo), select profile, then edit signature.
    Congratulations on taking over your pool.
    Hopefully you are going to let us see some pics!
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Ok fellas, I give up. How do I post pics of the equipment? I took some with my iphone but can't break the code on how to put them in a reply.
    Thanks.
    [attachment=2:2gc30tjp]IMG_0172.JPG[/attachment:2gc30tjp]
    [attachment=1:2gc30tjp]IMG_0171.JPG[/attachment:2gc30tjp]
    [attachment=0:2gc30tjp]IMG_0174.JPG[/attachment:2gc30tjp]
    Additional pics
    [attachment=1:lc89ybbz]IMG_0173.JPG[/attachment:lc89ybbz]
    [attachment=0:lc89ybbz]IMG_0175.JPG[/attachment:lc89ybbz]
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Pretty - unusual color - what kind of surface is it?
    Mar 2009
    Charlotte, NC
    539
    Quote Originally Posted by surgdog
    MK
    FYI, if for some reason you must resume tablets (vacation, one day you have to raise CYA, etc), I'm pretty sure we don't want those in the skimmer, can cause pipe damage, esp flex pipe (someone correct me if I'm wrong)
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Johnny B
    For now with the pump running 24/7 it's okay. If the pump is not on 24/7 then you want to use a chlorinator or floater. (The tabs are very acidic and can damage things if they just sit in unmoving water for too long.)
    --paulr
    BBB "Intermediate Swimmer"
    Thanks.
    In fact I bought a floater today and started using.
    Hi Mod Squad.
    It is a gunite?? (concrete) pool. It has a gray-green finish. It does look green but if you pull some water up in a clear vessel it is clear water.
    I can see the bottom very well.
