Results 1 to 7 of 7
Thread: starting BBB with CYA at 70
    Aug 2008
    Rochester, NY
    51
    Hi, I've been lurking for awhile and this is my first post. We had a 20000 gal inground put in 2 years ago. It is currently on an autofeed trichlor system with 3" pucks. I want to switch to household bleach. I just had my water tested at a pool store and the CYA level came back at 70. I have also invested in a Taylor k-2006 test kit but haven't received it yet. My question is...If my CYA level is actually at 70 and i switch to liquid bleach, will that be the highest the CYA will get? Will it start to diminish with water replacement from filter backwashes, lowering levels after rain storms, splashout etc? Thanks for any help.
    20000 gal IG freeform, vinyl, Pentair Sand Dollar filter, Pentair 2 speed pump, Pentair Intellitouch controller, Pentair Heat Pump. Built 2008
    SW Georgia
    300
    Re: starting BBB with CYA at 70
    I agree with your assessment.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Jan 2009
    Cupertino, CA
    1,966
    Once the pucks you have in there are gone, the CYA will stop rising. I wouldn't throw them away as the pucks are still useful for times when you are away on vacation or other trip (I keep mine for that reason). And yes, CYA will gradually drop over time for the reasons you say.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP! (or at least to your first posting)
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You've been around for quite a while.
    You're done SLAMing when:
    Aug 2008
    Rochester, NY
    51
    Thanks for the reply's and the welcomes. I am finding this forum a VERY valuable source of pool education. I am really starting to understand what all the #'s mean instead of staring blankly at a printed sheet from the pool company and buying what they tell me to.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    When I first found TFP my CYA was over 100. After a few partial drains and refills, I was able to lower it to 70. I got thru the 2007 summer at 70. 2008 I lowered it to 50. In 2009 we had a ton of rain and I actually found myself adding some CYA.
    Again this spring, it's low, around 20 - I've got trichlor in a floater for now..... never thought I'd do that again!
    Welcome to TFP!
