Thread: Repair vacuum hose end?
    Apr 2009
    So. Calif.
    4
    The swivel end of a 45 foot one and a half inch vacuum hose is coming apart.
    Is there available a repair part for this? I hate to buy an entire new hose.
    thanks
    16 x 36 25,000 gal IG vintage Alladin plaster pool with solar blanket
    DE filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Repair vacuum hose end?
    Yes, you can replace them. Here's one source Poolcenter.com They are near the bottom of the page.
    Apr 2009
    So. Calif.
    4
    Yes I did find the replacement part at poolcenter.com but the problem was that the minimum order is $10.00 and this part is $7.97.
    So I ordered something else that I did not need and instead of a 1 and a half inch swivel end, I received a 1 and a quarter non-swivel end.
    Returned the part and am still waiting for the correct part after almost a month.
    Will never do business with http://www.poolcenter.com again.
    DE filter
    Did you ever get the right part?
    I ordered both ends from them, and got both ends, but no instructions.
    They have female thread. I don't know if I'm just supposed to screw them on, or seal with silicone? One post elsewhere said that repair couplers (double male thread) are to be used with PVC cement.
    Anybody know?
    Lucy
    Intex Above Ground Pool 16' x 48"
    Approx. 5,000 Gallons
    Filter Cartridge
    1000 GHP Flow Rate
