Thread: Harbor Freight 1" Clear Water Pump test and review
    Apr 2010
    Las Vegas
    173
    I bought one of these little pumps a month ago and had to defective exchange it a few days ago. The following is a test of the new one. I don't like the pumps priming issues but if you get it going it moves some water for 40 bucks. Currently on sale for 30 bucks
    Link>> http://www.harborfreight.com/1-inch-cle ... -1479.html
    Factory Specs from site:
    *115 foot maximum total lift
    *Maximum capacity: 650 GPH SOme dispute here, The name plate says 330 GPH my test reveiled 400 GPH
    *Compact design with mountable feet
    *1/2 HP motor
    *Ideal for permanent installations
    *Cast iron construction
    110 volt motor
    3200 RPM
    Weight: 14-1/4 lbs.
    Link to factory manual (i tried to upload but it's 750K size prevented me>> http://manuals.harborfreight.com/manual ... 9/1479.pdf
    Specs on the housing:
    Brand: Pacific Hydrostar
    120 v~
    60 hz.
    1/2 HP
    2850 RPM
    Max Head Lift (Output) = 115 ft.
    Max Suction Lift (intake) = 10 ft.
    Capacity: 330 GPH
    Item 01479
    I used a Kill A Watt EZ for testing Link>> http://www.homedepot.com/Electrical/h_d ... ogId=10053
    Their cheap there now! 24.99 lowered from 29.99, some placed charge 39.99-44.99 for the same thing. And YES this is th emore expensive EZ model Look at the dark bezel around the display, thats the EZ.
    The difference is you can enter your Kw/hr rate into it and it will calculate cost and show it as a live updating number. SHows cost per day, week, month, year and Total cost since plugged in, using the build in time since pluged in counter. And there are several other measurments.
    Test results
    Testing voltage: 118
    Watts: 395
    Volt Amps: 591
    Amps: 5.0
    Power Factor: .66 <<thats ugly!
    operating cost per hr at 10 cents(check your local rates) per Kwh: 3.9 -or- 93.6 cents a day (24 hrs continuous)
    Inlet hose: 5 ft. 5/8" garden hose - 6inches lift from pool
    Outlet hose: 25ft 5/8" garden hose - 12inch lift into 5 gallon testing bucket
    Total lift 1 1/2 ft.
    FLOW: .111 gal/sec. or 6.66 gal/min. or 400 GPH
    20,000 gal. 32' x 17' freeform custom pool, 3ft. shallow - 8ft. deep end, Pentair Whisper flow 2.2 HP WF-6, Purex/Triton Nautilus FNS48 DE filter, 2 Intex Chlorine Generators (retired) SR Smith Rouge Rapids curved slide, The Pool Cleaner 4-wheel model w/Hayward large leaf canister. Tightwatt pool timer Spa: Beachport 5 person/350gal. Wishlist: move Neiko Tools pump to slide, solar system, Fountain, Automation. http://www.poolcalculator..com/
    Apr 2010
    Las Vegas
    173
    Re: Harbor Freight 1" Clear Water Pump test and review
    Overall it's a cute pump and pumps alot of water out my hose, its quiet without prime. When running and primed properly it makes a med-to-hi pitched matallic sound, kind of anoying. My first one went bad after one use. Harbor freight is intersting, lots of good deals but the defect rate can be high on some things, still their prices are killer, and a little inconveince is probaly worth it especially in this economy.
    Take note it can't run at all with any air in the pump chamber it's particular this way, and the manual specificaly says you will damage the pump if it is run with out priming first. So a check valve is pretty much mandatory unless your water line is above the pump itself.
    I bought one of these last year, for testing purposes only. Have an inground hot tub, who's plumbing was completely cut off. Needed to put some pressure behind it to see if I had any leaks. It did what it needed to do, and we went ahead and hooked the hot tub back up.
    HF is good for generics, or one-time use type of things. Zip ties, clamps, etc. If I buy a power tool, or anything else mechanical, I'm convinced that it won't work for continual use.
    This little pump has found another job, though. My brother does competitive smoking/barbecuing, and I engineered a setup that involved this pump, an old laundry sink, a used car wash detergent barrel, some PVC, and a shower head. Running water when there isn't any to be had.
    I have learned that if you disconnect this pump for a period of time, you better fill up the impeller housing with WD-40, or it will rust solid.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
