Thread: could it be algae
    Jul 2009
    Newnan, Georgia
    24
    could it be algae
    Hello.Our pool has something on the bottom of it not a lot just a few spots here and there.I think it could be algae,my husband says he thinks its just dirt.The water is clear but when I brush the bottom of the pool and brush over this stuff it makes a small cloud.All of our numbers seem good except maybe cc it is .5.The stuff looks yellowish/greenish to me but I do have trouble with colors sometimes.I have cleaned the filter and vaccumed and can't seem to get rid if this.Could it just be ditr that I am missing help please.
    25.6 K Gallon , 33' Round AG
    ProClean Cartridge Filter 125sf
    2 hp, 2 spd, 115 volts, 11.0 / 2.9 volts Waterway Pump
    Well water
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: could it be algae
    Might be algae, or it just may be where dirt accumulates in the depressions in the liner. To see if it could be algae check the following:
    1. Is the water clear or cloudy? If it is cloudy that could be algae.
    2. Do you keep the correct FC level as per your CYA? If you are inconsistent or run lower than recommended FC you could be on the verge of an algae bloom.
    3. Have you tested the water lately? Do you seem to be using more chlorine than usual? Might be algae. Do an overnight FC test to see if your FC holds overnight. More than 1ppm drop in FC indicates a need to shock.
    I get a lot of tree debris in my pool so I can vacuum it clean one day and the next day it looks like I never vacuumed at all! All the fine dirt accumulates in the same depressions in the pool floor.
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, as Zea mentioned, the Overnight FC Loss Test will rule out (or in) organics.
    Can you post a full set of test results?
    You're done SLAMing when:
    Jul 2009
    Newnan, Georgia
    24
    test yesterday were
    fc 4.0
    cc .5
    ph 7.5
    ta 70
    cya 30
    I know we need to bring the cya up a little but i thnk we are ok on the others.Isnt the fc plus the cc your tc and if that equals your goal ok?
    Well water
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Prepooler
    test yesterday were
    fc 4.0
    cc .5
    ph 7.5
    ta 70
    cya 30
    I suggest you leave your CYA level where it is until you determine whether or not you need to shock.
    FC + CC = TC; however, your GOAL is FC as listed in the Chlorine/CYA chart.
    Did you do the overnight FC loss test?
