Results 1 to 9 of 9
Thread: Acic, acid and more acid!
    Mar 2010
    San Diego
    24
    Please tell me if this is normal.....
    Pool re-plastered two months ago and since then I must have added at least 8 gallons of MA to keep pH in check....trying to get it down to 7.2 so I can get the TA down too.....
    Seems like lots of MA, just looking for reassurance that using this much is normal with new plaster.
    I have been adding a quart at a time, wondering if I should give it a bigger blast?
    FC 3.5
    CC 0
    pH 7.7
    TA 100
    CH 260
    CYA 50
    Borate 80
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Acic, acid and more acid!
    Yes, it is very normal.
    That is all normal. Fresh plaster raises the PH rapidly for the first three or four weeks, and then much more slowly for about the first year.
    On how much acid to add at at one time, your goal should be to lower the PH to 7.2 each time you add acid, however much muriatic acid that takes. You can use the Pool Calculator to get the approximate amount of acid that will take, and then you should double check by measuring the PH about 1/2 an hour after adding acid to see how close to 7.2 you got and adjusting how much you use the next time based on how far off you were.
    Mar 2010
    San Diego
    24
    Great thanks guys....will keep on keeping on with the MA.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by caljw
    I know how you feel Sometimes there seems like no end to adding MA! We re-plastered in '07.
    MA, brush, MA, brush, MA, brush, MA, brush ..........
    But, as they said, it will slow down and you will be hunky-dory with your new plaster
    You're done SLAMing when:
    Toms River, NJ
    151
    The borates will cause you to use a lot of acid, but the pool calculator takes that into account, so you should be fine.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    You've gotten the right answers
    (however, I thought this post would be about my first Dead show )
    Stick with us and we'll keep you trouble free throughout your pool owning experience
    Luv& Luk
    -Ted
    Mar 2010
    San Diego
    24
    Hey waste.....think I was at the same concert!
    BTW the water looks incredible thanks to the help of this site.
    Mar 2007
    4,160
    See, that's what this site is all about. The FIRST priority is keeping pools Trouble Free -- the second is to share the entire 'experience of pools/ yard/ BBQ"' and still be able to interact with folks who share similar interests, not pool related
    My first show was 03/ 26 (?)/ 85 - but I'd been listening to my brother's bootleg tapes for years before
    Luv& Luk
    -Ted
