Results 1 to 10 of 10
Thread: paramount valve and sand filter
    Central Indiana
    25
    Hi! I am a newbie and have greatly enjoyed the sight. I have an IG vinyl lined pool with a 24" diameter sand filter (36" tall) which came with the house I bought last summer. The filter has no labels on it. Could anyone tell me how many pounds of sand should be in the filter? We recently replaced sand, and I am not entirely sure if we added the correct amount. The cause for my concern is that we consistently run 23-28 psig and I have been told that my pressure should be closer to 15 psig.
    On a secondary note, I noticed that with my paramount gear installed (newly purchased last august), the pump will occasionally struggle with flow. This occurs when different sets of jets are flowing, so it is not related to any single supply to the pool. It is a 6-port valve. 2 on the floor and 2 sets of wall jets. I know the center is the feeder to the valve and the jets account for 4, but what do the other two pipes do? Thank you in advance!
    38' x 18' IG - Vinyl; 3' shallow end 12' deep end;~35,000 gal
    24" diameter x 36" tall sand filter, IC60 SWG
    Rheem Raypack P-M266A natural gas heater
    Paramount 6-port valve, 1.5 HP Pentair Pump, Autocover
    22,548
    Re: paramount valve and sand filter
    Take a picture of the filter and post it. We'll have a better idea of what it may be. The description you gave just described 90% of the 24" sand filters out there.
    Central Indiana
    25
    Sorry to take so long. Here is a picture.
    22,548
    Looks like a Pentair, either Tagelus or Sand Dollar. Can you take a pic of the top of the multiport valve? Maybe we can get a hint from that.
    Central Indiana
    25
    Here it is. There is no sticker on the tank. The multiport valve has no name brand on it, but the model number is 272526. Thanks.
    Looks like a Pentair Tagelus to me.
    22,548
    I concur.
    South Central NJ
    3,192
    Let's see the gear box for the Paramount. I suspect I know the issue there.
    Scott
    Owner of - PoolGuyNJ LLC
    Central Indiana
    25
    Quote Originally Posted by PoolGuyNJ
    Scott
    Here are a couple of pics!
    South Central NJ
    3,192
    If you are experiencing sharp rises in pressure when the system changes zones, Paramount makes a gear box that has a bypass pressure relief built in. In most cases, this short sharp rise isn't a problem but on some others, it is, be it short term leaks or tripping SVRS systems.
    Scott
