Thread: More questions about new TF-100 kit
    Sep 2009
    Madison, AL (north AL)
    77
    I have few more questions about my new TF-100 kit:
    1) In the instructions, some tests say to mix, others say to swirl. Can I just swirl for all tests, or does "mix" really mean to put the top on and thoroughly shake/mix for that particular step?
    2) If I know roughly what my TA or CH will be, can I put a bunch of drops in to start with, swirl thoroughly, then finish by doing one drop at a time and swirling in between each one?
    3) Tonight, for the first time that I've noticed, I discovered tiny purplish-colored "flakes" or particles in the solution while testing for CH. I believe this first started when the solution was phasing through purple, just before turning blue. Have you guys ever seen this, and does it mean anything in particular?
    Phillip
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    30,419
    Re: More questions about new TF-100 kit
    1. The only one to shake is the CYA test....swirl the others.
    2. You didn't hear it from me, but you can raidly add several drops and then slow down as you get to the roughly known result. Taylor really doesn't encourage you to do that and it can sometimes skew the reults, I think, but I've had pretty good luck with it.
    3. Those flakes are documented in Taylors description of interferences and I believe are a result of iron in the water but I can't remember for sure. They can be ignored
    Round Rock, TX
    529
    I saw the flakes when I had copper in my water. After a water change (due to other reasons than copper), I've not seen them reappear.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jan 2009
    Cupertino, CA
    1,966
    I don't know as I'd call them "flakes" but I certainly see "floaties" and I've noticed that they persist for a few drops after the bulk of the water has turned blue; but eventually they either turn blue or go away.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2010
    Fairfield, New Jersey
    22
    Quote Originally Posted by PhillipH
    Phillip
    Phillip,
    24 ft round pool $2000.00
    pump filter and accessories $500.00
    Magnetic stirrer for drop tests -priceless!!
    13K gal, Vinyl, 24' x 52" AGP, 1 HP pump, sand filter, 75 GPM, Chlorine
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Kenerator
    Phillip
    Phillip,
    The magnetic stirrer is so awesome. I recommend everyone who can get one. It will make testing so much easier and I actually have fun doing it.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
