Page 1 of 4 1234 LastLast
Results 1 to 20 of 64
Thread: Help please!
    Aug 2009
    OHATCHEE, AL
    33
    Help please!
    Help please!
    We were uncovering the pool a week ago, water was clear (dead alge on the bottom), corner of the cover sliped into the pool putting in some leaves and crud, fished the debris from the bottom, (lokks like swamp now), hooked up new sand filter w/new sand, filtering swamp water, clean skimmer basket and backwash daily. Took water to be tested today, readings are as follows:
    fc 0.2 ppm
    tc 0.2 ppm
    cc 0.0 ppm
    ph 7.9
    hardness 130 ppm
    alkalinity 40 ppm
    ca 10 ppm
    copper 0.14 ppm
    iron not run
    total dissolved solids not run
    phosphate 0.00
    Not sure what my next move is? What do I do next.? Thanks deb
    16x32x9 w/bottom sides go in about 4' down. IG, vinyl liner, new 2010 22-1/2" sand filter & new sand, 1/2 or 3/4 hsp. motor. 23,000 Gallons, Ohatchee, Alabama
    Re: Help please!
    Your alkalinity (TA) is too low. You should raise it up to about 70 and then lower your PH to around 7.4-7.5 before dealing with the swamp. Also, does CA mean calcium (CH) or cyanuric acid (CYA)? You want CYA to be around 30 to 50. CH can stay where it is for now.
    Next, raise the FC (chlorine) level to shock level for your CYA level. If CA isn't CYA, you will need to get your CYA level tested.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help please!
    Do you know how to use the pool calculator? You need to use it to figure out how much baking soda and CYA you'll need... we can help you figure it out if you get stuck...
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help please!
    First, you need baking soda to raise your TA to about 70 .
    Second, lower your pH with muriatic acid to 7.5-ish.
    Third, if your CYA level is really 10, raise it to 30. (You can raise it to 50 later (if you want) AFTER you are done shocking.)
    Fourth, shock your pool. Use liquid chlorine or bleach. See "How to Shock Your Pool" in Pool School.
    As FPM said, if you have problems with the Pool Calculator (link in my sig) please let us know.
    If you do not have a good test kit, do yourself a big favor and get one! See Test Kits Compared in Pool School.
    Many of us use the TF100 and love it! Link in my sig. You will save $$ and take control of your pool.
    Post back any question you have and someone will be around to help.
    You're done SLAMing when:
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    I had figured out that I needed the baking soda to raise the TA & the MA to lower the PH but couldnt get the pool calculator to work. It had said to enter info in the orange area, the only orange area on my screen is where you put the pool gallons?? If you wouldnt mind please tell me the quanity of each I need to ad.
    Right now I only have the Walmart 6 way test kit. I need to get me one of those you suggest but right now money is too tight and I cant afford it. I took my water sample to the pool store for these readings, also that reading of 10 way CYA.
    Thank all of you that help on here. Hopefully I will learn.
    "Yes I am Blonde":}
    11,969
    Re: Help please!
    Debra, I am blonde too. That shouldn't stop you
    I entered your numbers into the Pool Calc:
    You need to do it do so you can get the hang of it. It should look like the photo above.
    Enter your test results in the "now" column and enter your goals in the "target" column. Hit calculate. Then move your cursor over the boxes that have the results in them and it tells you in the large rectangle box at the top how many cups, jugs etc.
    Please give it a try - you will get the hang of it I promise.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    that would be 13-1/2 boxes of baking soda (2# boxes) & 13 oz ma right.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    from the pool caculator i got the above info (or at least with what i put in the pool cal. this is what i understand what i need to add to the pool), if that is the correct amount then when do i need to test again and start adding bleach? thanks
    Re: Help please!
    You should be adding chlorine (bleach) every day.
    You can test the water again as soon as one hour after adding chemicals, but you can also let it wait till the next day if you want to.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    we decided to just drain the pool. we will start refilling tomarrow. what will we need to put in the water after we refill the pool? do i need to test and get you the readings & go from there? a pool guy came by my house about a new salt water generator i am selling and he told me it would be the easiest and cheapest way to go in the long run. started draining about 2 today it's 5:30 now & the shallow end is empty, steps showing. thanks for any advice.
    Re: Help please!
    STOP DRAINING!
    Draining and refilling an in-ground vinyl liner can easily damage or destroy the liner. Unless there is something major you haven't mentioned, there isn't anything to be gained by draining and refilling, even if there wasn't any risk to the liner.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    too late, sorry, drained and 1/2 refilled.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    Last summer I spent over $500.00 trying to clear up the pool and was never able to get it clear. I am hoping there is no damage to the liner, it is looking really good so far. Got all the old water out by midnight Friday night, then started running the hose immediatly, been on all night and day today, water is about 4" from the bottom of the steps. The pool guy said it would be cheaper than the chemicals I would have to use and there would be no guarantee?? Sorry I didnt check here again last night but it was already too late. deb:{
    11,969
    Re: Help please!
    Debra, I understand why you spent $500 - I read your thread from last year. You were following the advice of the pool store.
    If you follow our methods, learn to use the pool calculator, take our advice and do as instructed, you won't ever spend that much again.
    But you have to learn to use the pool calculator, you have to keep reading the information in Pool School and putting it into practice - that's how you will come to understand everything.
    Our methods work - thousands can attest to that. The number one thing you need, is POP. Pool Owner Patience. Don't give in to pressure to use pool store chems or drain your pool...follow our methods, have the patience to let it work.... because it does work, and for a lot less money and it works alot better too.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help please!
    Ditto what FPM said
    When your pool is full, post a full set of test results so we can help you balance your new water
    Debra, once you get your pool balanced, it is very easy to keep it that way.
    When you read about the BBB method taking 5 minutes a day, we are serious.
    Example: For MY pool, I add a small jug of bleach (96ozs) each evening.
    Then about once a week I add 1 or 2 cups of MA. That's it!
    It really is that simple and inexpensive.
    And don't let the Pool Calculator worry you. You can learn it and we will help.
    We understand that it can seem overwhelming, but we have lots of folks here willing and able to help you.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    Thank all of you:}
    The pool is full (took forever), I will get a sample and post the readings. I dont have the good pool kit yet, have to wait until I get paid this week to order it.
    There is a small bit of debris in the deep end, we tried to hook up the creepy crawly but when we hook the hose into the skimmer the pressure goes to 0 on my new filter and wont pickup suction, any suggestions? thanks!!!:}
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help please!
    Quote Originally Posted by DEBRAPONS
    Fill the hose with water before connecting it to the skimmer.
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    ok hose is full of water but the pump wont stay primed.( wont keep wter in it at all). when i take the kreepey off i have to shut off the pump to get water to go back into it it will not prime its self.
  20. Back To Top    #20
    Aug 2009
    OHATCHEE, AL
    33
    Re: Help please!
    still having the problem with the filter and trying to vacum. (please advise)???
    just had the new water tested:
    free chlorine 0.0
    total chlorine 0.0
    combined chlorine 0.0
    ph 7.6
    hardness 110
    alkalinity 110
    cyanuric acid 5
    copper 0
    I am going to try the pool caculator to see what I come up with and check back and see what you say to see if I am learning anything or not??
    thanks deb:}
