Results 1 to 18 of 18
Thread: Adding Muratic Acid
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Adding Muratic Acid
    Hi, I am going to work on lowering the TA in our pool. Plan to use MA, to lower pH, then run the spa fountain to aerate. Is there any guidelines when adding the MA? I read to drizzle it in, in front of one the returns in the deep end. Is there a guide as to the volume of MA to add? I mean I can figure out how much to put in, using the pool calculator, [39oz] to lower pH to 7.2, but is 39oz ok to add, all at once even if I drizzle it very slowly?
    I couldn't tell you guys how much fun it has been, over the last few months, working on keeping our pool looking crystal clear and sparkly.... thanks to all the info, and people here.
    Today's numbers:
    FC-8.5
    CC-0.0
    TC- 8.5
    pH- 7.6
    TA-110
    CH-300
    CYA-70
    TEMP-72ish
    Looking to build a new POOL
    Re: Adding Muratic Acid
    You have it right. Use the Pool Calculator to figure out the quantity. Aim for 7.2 at first, so you don't cause any problems if you add a little too much acid. As you get more used to adjusting the PH you can aim for 7.0. Pour muriatic acid slowly in front of a return jet with the pump running.
    Whats your target for TA ? At this point I would love to see 110 TA , Mine is stubornly hanging at 230 last 24 hrs.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    MyBad's Avatar
    Feb 2010
    AZ
    60
    I would like to get it down to 80-90. Here is where I screwed up. We moved in last OCT. Never owned a pool and the pool was full of stuff, like tables chairs, umbrella, a gazillion cigarette butts, green water and so on. I fished all the junk out, hired a pool guy to just tell me what I should do. He tested the water using strips, went over the equipment with me, and gave me a list of stuff to buy and dump in the pool.
    So I did. Pool cleared up, But, I put a lot of stabilizer, and acid in all the wrong way. Then he told me just to use pucks in the floater, and test with the strips I had. I wish I would have come across this site before all that. Anyway here is a pic of it all cleaned up and nice.
    Sounds alot like what I went through last year , wound up with scaling and such. Will pay way more attention this year ).
    coloeb,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by MyBad
    Today's numbers:
    FC-8.5
    CC-0.0
    TC- 8.5
    pH- 7.6
    TA-110
    CH-300
    CYA-70
    TEMP-72ish
    I usually add acid 2 or 3 cups at a time. My technique is this: I have a small clean plastic pail. I scoop a gallon or so of water out of the pool with it. Measure and pour the acid into the pail of water. I measure over the pail, in case of spills. And right at the edge of the pool. Reach in with the cup and rinse the acid off in the pool. Then I pick up the pail and sling the contents at the center of the pool, as far away as I can. It usually hits the surface in a strip about 10' long and maybe 1½' wide. The splashes don't make it to the edge, usually. And if they do, I don't worry - my junior high science teacher told us to pour acid into water so if there's a splash, it will be water, not acid. Something about if you toss a rock into a lake, water splashes out, not rock. But I digress.
    After that, I rinse the pail in the pool, and carry everything back to the shed. Then I grab the brush and start brushing. By the time I've gone around the pool, I'm confident it's well-mixed.
    Jan 2009
    Cupertino, CA
    1,966
    Richard320: What, your pump is broken? Sounds like Too Much Trouble to me.... pour slowly (~an ounce at a time, ~5 sec between pours) in front of a return. In the daylight I can see the swirly shadows on the bottom of the pool as the jet stream carries the acid away. After that, it is mixed!
    (The splash trick wouldn't work for me, the acid would all end up on top of the cover.)
    --paulr
    BBB "Intermediate Swimmer"
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    please do not sling acid (even diluted)...with the wrong release technique (which I'm sure you have down pat) accidents can happen...even Tiger slices a ball here or there
    Toms River, NJ
    151
    Quote Originally Posted by PaulR
    At that rate it would take me all day to add borates using borax - I need 10 gallons of MA to maintain pH. I think a slow, steady, continuous stream in front of a powerful return is safe, no?
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Yes, a slow steady stream about the diameter of a pencil is good. Of course, the pump needs to be running the entire time.
    When pouring large quantities, make sure to wear clothes that you don't mind getting damaged. With practice adding a cup or two isn't much risk, but doing gallon after gallon raises the odds that you will get a drop on your clothes at some point.
    Jan 2009
    Cupertino, CA
    1,966
    baudilus, we were talking reducing-pH quantities not adding-borax quantities. When using multiple gallons, the trick of floating the jug in the pool while you pour would go a long way to reducing splash.
    --paulr
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by dmanb2b
    Is that what they are calling it these days.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Added the acid today and TA was down to 100, from 110 schweet!
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful pool
    You're done SLAMing when:
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Quote Originally Posted by Butterfly
    Beautiful pool
    TY, it is getting there
    Aug 2009
    SW Wisconsin
    518
    Man..a TA of 110...what r u worried about??? Go swim and fuggettaboutdit. Man...if my TA was there, I'd be relaxing on my pool lounge with a beer and worrying about testing next week.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Amen Flyweed!!!
    I've come down from 200+++++++ to 130 at last check. I finally just turned off my country fountain and put my return in the right spot for best circulation...when the guys are done blowing sawdust everywhere, I'll worry about TA again...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    I started putting the MA bottle in the pool and tipping it in the pool a little in each return to the pool.....no smell that way and it appears the acid is heavier so comes out....when I take the jug out some water does go in so acid in bottle gets a little diluted for next time....no more getting knocked over by a faint wiff!
