Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: So BBBers, how long since you've shocked?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    So, how long has it been since your pool has needed shocking? I bet it's been a llloooonnng time for some of you old-timers. For me, I've owned a pool for 7 1/2 months and haven't needed to shock yet.
    This is more to satisfy my curiosity than anything, but it could actually help someone if they don't quite trust BBB. It works!
    Feb 2008
    Denton, TX
    5,061
    Re: So BBBers, how long since you've shocked?
    Umm...about a month ago.
    My fault. I let the chlorine go to zero. Too much on my plate at the time but really, I'm just making up excuses for myself.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    I shock when I open the pool and again when I close it. I'd be shocked if I had to do it in between those times!
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Oct 2009
    3,899
    OK, how about besides opening/closing shocks?
    Ohio
    217
    in last 4 years I shocked at closing and sometimes at opening and usually ad CL at the first thaw That is it. Also I keep my TA at 60 and check PH and CL daily I have used 4 cups of acid in the last 4 years and no polyquat at closing.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    tedinelkgrove's Avatar
    Jul 2009
    Elk Grove, CA
    98
    Maybe once or twice when I let FC get below 2ppm (CYA 30-50). But I have never had to shock due to an algae outbreak, knock on wood. BBB has been great.
    ~15000 gallon inground, plaster pool
    Jandy CL460 Cartridge Filter Tank, Jandy Stealth SHPF 1.5hp pump, Pentair Legend II cleaner
    Leslie's DPD Complete Test Kit, TF Tests FAS-DPD Chlorine Test Kit
    Heliocol solar pool heating (HC-40 x6)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    "NEEDED" shocking? 2007.
    Mar 2009
    Huntsville, AL
    156
    My pool was installed March 2009, which is when I found this site. I've have never shocked my pool.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I was lucky and found the BBB philosophy before my pool build was complete. This will be my 4th year and have never needed to shock.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    22,543
    Add me to the never shocked category!
    Shocking now. According to records I'd only tested the pool 4 times since November. I'd been adding bleach when I thought about it but not the 2 jugs a week that I know it typically needs. Then it got HOT and I was not thinking about the pool, doing irrigation repairs and planting stuff. FC fell to 0 and then I noticed a smear of algae in the hot tub. So, got out the full test kit and checked the numbers. Pool still looks good, just not sparkly enough for me. So, clean the filter carts and up the FC for a few days. Clear blue pool got a touch of cloudyness with all the Cal-Hypo and came close to holding overnight but not quite. So one more day and night. And I NEED to put this on my calendar reminder.
    May 2009
    Enterprise, AL
    54
    Put me down for the "never shocked" category. Haven't had the pool for a year yet, tho. Very few close their pool down here.
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Wow, you guys are a bunch of showoffs! J/K
    I'm joining the anona and 257 club
    Okay, we shocked our pool the first week of April, 2010.
    Took two days to go from green to beautiful sparkly blue
    ETA: Even a BBB pool can turn green if you ignore it for several months.
    You're done SLAMing when:
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I started BBB last June and have not had to shock since. I do maintain chlorine/bleach and filtering through the winter.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Aug 2009
    North Central Texas
    1,358
    No cover; open year round; tons of blowing large and small debris and high winds year round. Switched to BBB late last summer. Haven't had to shock since then. For several months during winter and into early spring I didn't have the main pump and filter running but kept water circulating with two small submersible pumps and added Slime Bags for fine filtering to the hose ends when it started warming up and waiting to get my new filter and pump in. Still didn't need shocking as kept chems balanced all winter; mainly addition of 6% bleach every few days. Also ran Aquabot (operates independently of pool system) cleaner during that time that kept most of the large organics from woods (year round here from blowing winds) from staying in pool for any length of time. Aquabot kept a lot of water circulating too and fine particle filtering; about 4K gallon per hour.
    Keeping the water moving is vital if pool isn't closed and covered, especially in warmer climates.
    BBB
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    It has been about 22 months since I had to shock. We went on vacation for four days without a pool sitter, there was an especially windy day while we were away, the skimmer got blocked with leaves, the automatic prime protection shut off the pump/SWG to protect the pump, and we came home to a wonderful green pool. We don't have a main drain. If we did, things would have been fine even with the leaves. Last summer we were away for at least that long several times without problems.
    Aug 2009
    North Central Texas
    1,358
    Bummer but good lesson to be learned for all of us.
    Perfect example of what can happen in just a few days without moving water and adequate sanitizer. That's one reason I'm such an advocate of small inexpensive submersible pumps to keep water, at the very least, moving. About the only thing that can go wrong is lack of electricity.
    I have to have a doggie sitter when we are gone for more than 12 hours so we get a built in pool sitter in the deal. This last "vacation", almost 9 days, last month, doggie sitter was in tears trying to keep the debris out of skimmer and Pool Skim, and managing the Aquabot.(She didn't tell me, rather DH found out when he called her to check on things.) AND the pool was PERFECT when we returned.
    If I didn't have to have a doggie sitter I would shut the system down, throw in the two submersible pumps, for circulation, and put a couple of floaters in with TriChlor. Neighbor would come over to put more tabs in floaters an/or bleach, if needed. If the CYA went up just a little that's easy to deal with; one backwash would take care of that. But it wouldn't go up that much in a week or even two. A couple of days of running a cleaner and pool would be clean again. That's if it's summer when we have less plant debris blowing in.
    gg=alice
    alan70062's Avatar
    Apr 2010
    Metairie, LA
    8
    I am glad you asked that question because I am new to the BBB method, which by the way is working out great for me, and I was wondering when to shock. My water has been crystal clear so I am guessing from other replies that if you keep up with the daily/weekly checks, no need to shock the pool. I was using Pristine Blue for the last 8 years and was looking for other options when I stumbled upon this website. The water has never looked so good!
    Alan
    12,000 gallon, 15'x30' above ground, vinyl liner, 1.5hp pump, sand filter. Metairie, LA
    Sep 2007
    Lafayette, Louisiana
    344
    My pool has been in service for 2 years now. The only time I've ever had to shock is when I went offshore for a few weeks and a power surge shut my SWCG off for some reason. There's no need to shock a pool if you keep up with the chemistry. The pool stores will tell you different...
    Jim
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
  20. Back To Top    #20
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I'm in a constant state of SHOCK sorry couldn't help myself.
    Seriously 2 weeks of nonstop shock due to pool being closed for 3 years.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
