Results 1 to 14 of 14
Thread: new liner put in and pool refilled, numbers are looking sad.
    Oct 2008
    Georgia
    24
    just refilled my pool after liner replacement, here are my numbers:
    FC....0
    CC....0
    TC....0 WHAT A SURPRISE...
    pH....7.8
    T/A...110
    CYA...0
    now my question, with what do I start? I thought with the CYA...but I am not so sure. If anyone can give me a hint, I really would appreciate it. Don't want to waste money on chemicals by doing it in the wrong order and chemistry just wasn't my strongest subject in school...Thanks in advance, looking forward for some answers from the "pro's"
    36x16 in ground vinyl pool, 21500 gal
    1 main drain, 3 returns, 1 skimmer,
    overflow,
    Polaris 280 auto cleaner,
    Hayward high rate S-244T sand filter
    Hayward 1HP pump and booster pump,
    SWG Pentair IntelliClor
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: new liner put in and pool refilled, numbers are looking sad.
    Ph first, then add 2ppm chlorine. Then get some CYA in there, target 30 to start. You can do all three things on the first day - just don't add acid and bleach at the same time.
    CYA is a great place to start. You want to raise CYA to between 40 and 50. I would also lower the PH to around 7.2, but there isn't any rush on that. Add 2 ppm of chlorine after dark tonight and then, if you add the CYA today, start aiming for a FC level of 4 to 8 tomorrow evening.
    Hum, frustratedpoolmom beat me to it.
    Oct 2008
    Georgia
    24
    Thanks for the quick replies....and the confusion, CYA or ph???? Or doesn't it really matter? I feel sooo pool un-educated, it's just confusing to me, please let the ole' alien know.
    overflow,
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    pH, chlorine, CYA. Just give the acid a half hour or so before adding chlorine. CYA could be added before, inbetween, or at the end. It takes a while to dissolve.
    Oct 2008
    Georgia
    24
    Thanks so much, will get started right now, but I am pretty sure, that I will be back soon with more questions.
    overflow,
    Oct 2008
    Georgia
    24
    and here I am again, put CYA in a sock in the skimmer, now my question: Does the filter have to run on cleaning or is it enough to set it on cycling, just to stir the water up???
    overflow,
    Oct 2009
    3,899
    I've always just left in in the skimmer and run the pump as normal. It won't hurt anything sitting there when the pump is off, and it'll slowly dissolve over a few days. You're doing fine!
    Oct 2008
    Georgia
    24
    ...and back again! Added stabilizer and since it took 5 days to refill the pool, I shocked too. Here are my numbers:
    FC...........8
    CC...........0
    TC...........8
    pH.........7.2
    TA.........110
    CYA.........40
    Temp.......74
    I think the numbers are acceptable....guess the FC will go down, since I shocked yesterday.
    Thanks for all of your advice and help.
    overflow,
    30,432
    YOur numbers look close to ideal......how does your water look?
    Oct 2008
    Georgia
    24
    crystal clear....what would be ideal???
    overflow,
    11,969
    The PH is a tad low... that's all
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by frustratedpoolmom
    Party pooper
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Oct 2008
    Georgia
    24
    Borax it is....my happy behind will get in da pool tomorrow, Temp was 78F today......I guess slowly I am getting there, thanks to all of your poolish wisdom (insert big smile...).
    You guys rock!!!!
    overflow,
