Thread: Return Fittings
    Jul 2009
    Long Island, NY
    267
    Return Fittings
    Is it okay to grease the threads on the return fittings to make adjusting them easier? I have a tube of Leslie's Pool & Spa lube that I was considering using for this.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    22,549
    Re: Return Fittings
    I lube mine with silicon o-ring lube and the pool and spa lube you have is probably the same thing.
    Jul 2009
    Long Island, NY
    267
    Re: Return Fittings
    Thanks. I'm not sure but I think the Leslies product may be teflon based. The label says something like "contains Dupont fluropolymers" or something like that.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Return Fittings
    Yup, that's Teflon. Should be fine.
