Thread: Vacuuming w/ cartridge system
    We just filled our pool and there is a light coat of silt on the bottom...from the air and possible residue in the pipes. We have a Hydromite cartridge filter HM100. The filter has an attachment at the end that fits/seals into an opening at the bottom of the cannister. These plastic seal pieces are glued to the bottom of the filter and tend to separate from the filter (glue gives). Anyhow, I went to vaccum the pool bottom and all seemed well until I vacuumed the steps. I accidently sucked in a little air and it appears that the air caused the filter system to empty the silt back into the pool through the jets.
    I assume the air caused the filter to lose its seal with the bottom of the cannister and water proceeded to bypass the filter back into the pool...bringing the filtered silt with it. Is that likely the problem? Does the force of the water flow maintain the seal between the filter and cannister? Would air in the sytem cause that seal to fail...making it necessary to blead the cannister of air?
    Any advice?
    thanks,
    Andy
    pool size 20,000 gallons
    cartridge filter...Hydromite HM100
    Inground tile surface
    Sta-Rite Dura Glas 3/4 HP single speed pump
    Test results Rainbow Lifegard kit
    CL just under 3.0
    PH 7.8
    Feb 2008
    Denton, TX
    5,061
    Re: Vacuuming w/ cartridge system
    That's very strange. I would probably stop everything and open the filter to allow for an inspection of the cartridge(s). It sounds like the filter membrane might no longer be intact. Those cartridges are held in there pretty secure and I can't imagine that a little bit of air getting in there would cause them to lose their seal.
    Oh, ok. I see what you are saying now. Yes, if the seal is separating from the filter membrane as you describe, it's time to replace the cartridge.
    22,553
    Baker Hydro was bought by Waterco back in 2005. If you need a manual or anything you can probably contact them for it.
    Thanks for the input.
    Andy
    CL just under 3.0
    PH 7.8
