Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Topsoil is good for pools, right!? (now with photos!)
    Just when I thought the fun was over with my pool, a careless contractor came in and kicked the fun up to 11.
    This morning, I had 10 yards of top soil brought into my back yard to level out the clay and plant grass. He dumped it where it was supposed to be and then, while shaking the box to empty the tailgate, backed some of the pile into the pool!
    The pool immediately went black with the flood of new soil. Luckily, I screamed at him just as the dirt was pushing over the ledge and it was only a few hundred pounds of dirt. I turned off the pump as I had to go back to work and didn't want it clogging anything up.
    Ugh.
    Back to vacuuming again. :\
    UPDATE: This is the pool 2 days after the dirt hit it, pump off the whole time. You can see the lines where I've been losing water and the mess they made. Tomorrow, my yard crew will be done planting grass seed and I'll get to cleaning it.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Apr 2010
    Plano, TX
    44
    Re: Topsoil is good for pools, right!?
    Oh man. That stinks. Sorry you have to deal with that.
    Plano, TX
    25,000 Gallons, Plaster, DE Filter, No SWG
    Ottawa, ON, Canada
    153
    Any pictures?
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    May 2009
    Jasper, TN
    249
    Yeah, man I hate to hear that... but like a wreck in the road you have to stop and look... so where's the pics?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Hopefully it's in the shallow end. You could get in and shovel out the worst then.
    Pictures would be nice. Before/after will be a testament to your abilities.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That's a lot of filter cleaning...
    Dec 2009
    Laguna Niguel, CA
    35
    Hate to hear this - hope you can get it completely out of the entire system without too much trouble.
    Contractors....uggghhh!
    18 x 28 with 8x8 Spa with Vanishing Edge Dam wall, Pentair 4 x 160 & 2 Whisperflo, Badu Swimjet SuperSport, Pentair 400Kbtu Minimax, 80sqft DE CAT 1000 PH Controller with Stenner Pump/Tank combo
    Butterfly's Avatar
    South Carolina
    10,045
    Holy cow! And after you worked so hard to get it cleared!
    Let's be glad he did not back into your new fence!
    Keep us posted on the cleanup.
    You're done SLAMing when:
    I'll see if I can snap a few pictures tonight. What a mess.
    Clearwater, Florida
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    Holy Cow! I would make him pay for clean up or a heavy discount on the soil.
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I can't imagine the ten levels of mad I would go through...
    I admire you for not throwing HIM in the pool...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    That's a lot of vacuuming to waste
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    That guy (or the company he works for) should pay for the cleanup of your pool and refund you for the amount of topsoil you paid for that they destroyed. I say destroyed because unless you plan to remove it by hand and spread it out to dry somewhere I doubt you will be able to salvage it!
    Love TFP? Become a
    TFP Supporter!
    Quote Originally Posted by Hurricane Gio
    When I attempted to negotiate that he said, "I'm just a guy with a dump truck. I don't own a business. I'm just bringing you dirt for cash. I'm not responsible."
    Clearwater, Florida
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by denisbaldwin
    Did you pay him? I would have refused payment. Did you pay with a credit card? dispute the charge.
    Jul 2009
    Houston, Texas
    9,409
    Re: Topsoil is good for pools, right!? (now with photos!)
    That guy with a dump truck should have insurance! Make a claim! If not go after him in small claims court!
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    Where I come from, we call him self-employed. Among other things, he should get some insurance!
    His business is selling/delivering 'dirt' for cash. If he is not more careful, someone (maybe you) could end up owning that dump truck.
    I am not saying he owes you his dump truck, but I think he owes you something. JMHO
    Butterfly's Avatar
    South Carolina
    10,045
    If you are viewing by the 'latest post' and wanna see the pics of the damage, Denis added them in his first post
    so.....scroll back up..
    Thanks for the pics!
    The more I think about it, the more I think I'm going to take action.
    I paid him cash before he dumped it. That was probably my first mistake. He wouldn't take a check or credit card, so cash it had to be.
    Secondly, I'm not even sure if I have his information anymore. He was an ad in the local newspaper that I had called to hire him. When I call him now, it goes direct to voicemail. I'll give my lawyer all of this info and see what he can make of it.
    Clearwater, Florida
  20. Back To Top    #20
    Jul 2009
    Houston, Texas
    9,409
    Try googling the phone number to see if it is a publicly listed. You can also try calling from a different phone and see if he picks up. He is likely trying to operate under the radar of the IRS with this "cash only" stuff. Did his newspaper ad say "so-and-so dirt hauling" or "just-a-guy-with-a-truck-who-delivers-dirt-and-won't-be-held-responsible-for-damaging-your-property"? He placed an ad offering a service for a fee. That makes it a business. Reporting him to the state attorney general may also be an option.
    Love TFP? Become a
    TFP Supporter!
