Results 1 to 9 of 9
Thread: First large Pool Party next weekend...
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    I will be having my kids Birthday Party next Saturday and it will be the first party in the Pool. I am expecting 20-22 bathers in my pool.
    Is it a good idea to shock the pool with bleach before or after? Or should I just bring the levels up slowly with my SWG little by little to a bit over my normal levels?
    The wife is afraid if I shock with bleach before and mess up that we can't swim. But I told here I use the TFP and the Pool Calc and she gave me a strange look, LMAO!
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: First large Pool Party next weekend...
    I'd just run at the high end of the range before the party, then shock it after the party. Your pool will eat chlorine for several hours with that many kids.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    As long as the chlorine is in the top of the range you should have no problems. If you want to shock after you can, but you may not need to. Make sure everyone understands the no peeing in the pool rule and maybe set out some old towels on the floor of the house to keep the path to the toilet dry.
    Love TFP? Become a
    TFP Supporter!
    More people in the pool means more chlorine demand, with enough people way more chlorine demand. As long as you add enough chlorine there isn't any need to shock. Figuring out just how much chlorine you need is a little hit or miss so be sure to test the level right after the party.
    Wow!!! That's a lot of kids! Good luck to you! Make it a rule in your house/pool....go pee before you go swimming! I tell my kids and their friends...I have put a special chemical in the pool...if you pee in my pool your bathing suit will turn red!! OMG...you should see the looks on their faces!!!
    28,000 IG Free Form Gunite with quartz finish
    Pentair Quad DE filter, Intelliflo VS+SVRS
    Polaris 280, Sta-Rite 400K Heater-Propane
    Feb 2008
    Denton, TX
    5,061
    For what it's worth, we have done several pool parties like that. I usually dose the pool before the party to get the FC level to 2.5 ppm above target as indicated by the Chlorine CYA Chart. Following this route has kept me from having to shock afterward.
    Apr 2010
    Coral Gables, FL
    197
    Thanks guys. Its about 15 kids and 12 adults. All the kids are potty trained except for my soon to be 3 yr old boy (in the process) and know not to pee in the pool.
    I will just keep chlorine just a hair over my preferred levels and test fix/handle on Sunday any issues.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I've had several pool parties over the years - a bump of 2-3 over normal has always been plenty and I've never had to shock after.
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by frustratedpoolmom
    thanks FPM
