Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: White underwater epoxy
    Vero Beach, FL
    462
    The leaks around my drains were fixed using a 2 part epoxy putty that hardens underwater. Anyone know where I can get some? I've got a small bit of metal in my pebble tec plaster that is rusting. I want to chip it out and fill the hole with the epoxy.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Feb 2008
    Denton, TX
    5,061
    Re: White underwater epoxy
    How big is the metal piece? I wonder if it would be possible to glaze over it with a dab of clear epoxy so that you don't have to chip out any of your pebble tec.
    I worry about you trying to get the piece out without knowing just how much of it is really in there. You could end up chipping out more than you bargained for.
    Is your pool still under warranty? Might be good to let the PB resolve it if it is.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    lborne try West Marine or a Marine Boat store. We were heavy into big boating before we retired to the pool world.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    MarineTex is the product you're looking for.
    Guest
    I've bought it a Leslie's before. http://www.aplusbputty.com/
    Works Great! You can call them and see if they carry it at a Vero Beach Store. Aplusbputty's website says Leslie's carries it.
    Goo Luck!
    Vero Beach, FL
    462
    Quote Originally Posted by 257WbyMag
    Thanks. Its about 2 x 3 mm. When brushed, it just looks like a black spec in the normal pebble tec, but then after a day it is larger and turns rust colored. I have access to some underwater tools so was going to grind it down just a bit and epoxy over it.
    Yes it still in warranty and I've got several other things I want the PB to fix (couple other rust spots in the tile grout area) but he's been unresponsive. Getting to where its just easier for me to fix myself.
    Solar heat
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by lborne
    I hear you there. Sometimes when you want something done and done right, it's best to just do it yourself.
    I've never been one to delegate much. It's a flaw of mine.
    Vero Beach, FL
    462
    Black algae or rusting metal chip?
    In a previous post I mentioned that I think I have a small metal chip in my paster that is rusting. Its very small - smaller than a pea, but left for a day, it grows to about double its size. When brushed, it looks like rust and plumes of rust can be seen coming off, and then its back down to its small size.
    Using a tube I put muratic acid on it which just made it turn rust colored until I brushed it and it is back to a blackish color.
    I caled the PB and he is saying its black algae (although he has not come out to look) and so I just need to shock the pool.
    CYA = 80
    CH = 7, but did go down to 5 one day while my SWG was being fixed.
    Ph = 7.6
    All other numbers are within range.
    One other note - I did add extra salt by mistake and am at 4700 instead of 3500 and that is about when this stain appeared (out of nowhere).
    How can I check to see if it is algae or not? If it is black algae, and I scrubbed it with a chlorine tablet, would it go away?
    Solar heat
    Feb 2008
    Denton, TX
    5,061
    Re: Black algae or rusting metal chip?
    Um...I'm going with rusty piece of metal on this one.
    If it is black algae and you scrape it with a trichlor tablet, it will go away.
    Vero Beach, FL
    462
    I hope you are right. From what I can tell, black algae can't be made smaller simply brushing with a nylon brush and would not release a plume when brushed - correct?
    Whereas the metal rusts and stains the plaster around it which makes it look bigger until I brush the rust stains away.
    Solar heat
    Feb 2008
    Denton, TX
    5,061
    Right. That and the fact that your salt level is higher than called for might give a little more corrosive effect to the water than it normally would have.
    If you scrape a little bit of the spot off with your fingernail and rub it on a piece of white paper, algae will look green, while rust will look red/brown.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Can you take a picture? I'm a little curious since there was a thread on here a little while ago (can't find it now) where someone was considering a pebble color that had a lot of magnetic (read easily oxidized iron) material in it.
    Vero Beach, FL
    462
    After taking some underwater photos at lunch, I think it is clearly some metal just under the plaster rusting through. Below are 2 photos - the first before brushing and the second after brushing. The rust growth is evident in the first photo. The black splotch to the left is ??? - must be a dark color pebble. Got lots of blue and grey, some black and even a few red pebbles in the mix. Or more likely, its also a piece of metal just under the plaster surface.
    Wedding ring thrown into second photo for size ref.
    What does everyone think?
    [attachment=0:2ne3sjnx]P5054302.jpg[/attachment:2ne3sjnx]
    [attachment=1:2ne3sjnx]P5054313.jpg[/attachment:2ne3sjnx]
    Solar heat
    Vero Beach, FL
    462
    I've posted a photo before and after brushing in this post....
    post170093.html#p170093
    Feel free to delete this post. I should have only started one.
    Topic merged. JasonLion
    Solar heat
    Oct 2009
    3,899
    Rebar? Those two spots seem too big to be merely an iron-rich pebble (you can see the spot surrounds/includes/stains several pebbles).
    Vero Beach, FL
    462
    I've got the exact same problem in the 2 shallow end corners except its coming through the tile grout. Odd because there was no hint of rebar coming out of the shell, and the plaster went on pretty thick. I do think it is rebar at the corners - but this spot could just be a piece of metal that was in the mixer - ????
    Solar heat
    Oct 2009
    3,899
    Maybe not rebar, but it certainly looks like it's coming from behind the plaster. Hopefully one of the pros will offer their wise counsel...
    Guest
    Could be the wire tie for the rebar??? You should see if you have someone that can do underwater repair, We have a guy out West called The Pool Dentist.
  20. Back To Top    #20
    Vero Beach, FL
    462
    Does everyone agree that my photos are of rusting metal? PB came by and looked (but without getting into the pool) and said he still thinks it is some kind of algae because he's never seen rust spots in plaster.
    Solar heat
