Good to hear. Once again, I'm sorry I was rude. It was just that the product seemed so fake and phony, but I would too spend $500 just not to have to dump bleach in my pool everyday.
long time pool gal said:And yes, if the unit had cost me $500 or more, I probably wouldn't have even considered it as well.
salp said:I am still waiting for the answer on how much brine waste from the RO section of this system. The "Bad" water from RO has to go somewhere, How much are you wasting?
My name is Daniel M Tucker I am the inventor of the Chlorine Genie I have been in the pool business for over 40 years, mostly connected to salt water generators. I don't know who "the Long time pool gal is" but I thank her for the time she has spent posting her comments about the Genie. Most of the negative statements are coming from people that really don't know much of anything about the way the Chlorine Genie works or how it is installed. For clarification:
1. The Genie is either installed on the equipment pad or by a fill line to the pool.
2. Clean water softener salt is put into the Genie brine tank usually a 40 or 50 lbs bag at a time
3. The Genie only uses House hold water that is delivered with 1/4 inch tubing (like an ice maker hook up) is delivered to the unit.
4. Chlorine gas is generated at the anode electrode and is mixed inside the unit with the by pass water from the RO unit.( no water is wasted)
5. Because of a selective membrane between the cell electrodes, the Genie make its own mild acid and base product for pool pH adjustment eliminating commercial acid and soda ash.
6. Holding a 1 to 2 ppm free chlorine reading on a 20 to 30 thousand back yard pool will require salt to be added to the unit 4 or 5 times a year. (around 25-30 dollars per yr.)
7. When the cell needs cleaning, every couple of months you can acid wash it with the simple turn of a dial on the face plate.
Thease are the basic FACTS about the Chlorine Genie. Thousands of these units have been installed, mostly in Northern California and units are now being shipped to pool people through out the United States.
One more FACT. Daniel M Tucker has now been issued from the United States Patent Office over 40 patent claims on this Technology.
In my opinion I believe the Genie is setting a new, higher and much easier method for pool water maintenance.
Were considering getting a chlorine genie because we are redoing our entire pool system: pumps, panel, heater, and filter. Being a new pool owner, it sounds good to me and the price I was quoted is $2,900.
