Thread: New liner is in
    Oct 2009
    SW IN
    14
    New liner is in
    The new liner was installed last thursday. I have an 18 x 36 inground Foxx vinyl liner pool. After filling, I added 6lbs of stabilizer friday. I know I need to wait a week to get an accurate reading on CYA levels. Here are my test results so far.
    FC 1.0
    TC 1.0
    PH 7.8
    Alkalinity 160
    Hardness 190
    TDS 400
    The chlorine seems a little low. Since total and free are the same each time I test, do I need to shock the pool? Also I am more used to battling low ph. Should I drop both Alkalinity and Ph? Thanks for any suggestions.
    25k-30k gallon IG plaster/shotcrete
    Pentair 1 HP Hydropump
    C-9419 catridge filter
    Kreepy Krauly attack monster
    And ooooo, a diving board - WHO WANTS TO TOUCH ME? :)
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: New liner is in
    No need to shock just bring up your FC to about 3 to 4. Make sure it holds overnight and your good. Yes you are on the high end for both ph and TA so bringing them down a bit will help.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Oct 2009
    SW IN
    14
    Re: New liner is in
    Thanks. I forgot to mention one thing. The pool capacity is 25000 gal.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New liner is in
    Yes, I would lower the PH to 7.2. The TA is a tad high but that won't hurt anything other than maybe cause the PH to drift back up. If it does hit 7.8 again, just lower it back down to 7.2 with muratic acid. Each time you add acid the TA will drop a little and eventually both will be in range.
    Whoozer is correct, if your FC holds overnight there is no reason to shock.
