Results 1 to 12 of 12
Thread: Common Depths of play pools help
    This is my first post but will have many in the future. We are getting a pool built at our house and decided on a play pool. One where we can play sports (volleyball and basketball). However we would like it deep enough where we dont scap our knees. So I need to get some advice on depths that people recommend. Right now we are looking at 3 depths in the pool of 4ft, 5ft, 4.5ft. In those order on the pool. But remember we have NO prior knowledge on this. So please let me know what you guys think before its built.
    33x24 gunite pool, hayward4.0 LED light, vs-3050 pentair pump, clean and clear plus 520, rainbow 320 chlorinator
    Jul 2009
    Shawnee, Kansas
    92
    Re: Common Depths of play pools help
    I am not sure if mine is the same thing, but it sounds very similar. I have a 'sport' pool. Mine is 3.5 feet deep on each end and 5.5 in the middle. Playing volleyball in it is a BLAST!
    Matt
    20,000 gallon, sand filter, IG vinyl
    We chose to do 5.5 feet in the middle, with 3.5 at the stairs and 4.5 at the other end. Went with the 5.5 depth as we are taller than average. After the gunite was shot we realized we made a big mistake by walking around in the shell with a laser level to simulate the water level at night.
    A majority of the pool was over 5 feet deep, and the parts that were not too deep were too steep to stand on comfortably. We ended up having about 20% of the pool being useable.
    There are a lot of variables such as pool size, shape, the way the crew forms the bottom, etc. Based on my experience I would recommend a max depth of 5 feet. Anything deeper and people can't stand up and hang out, but it is too shallow to dive into. I would also recommend being around they day they shoot the gunite and checking depths / slopes. If you want more gunite when the truck is onsite it is cheap. Having the truck come back out costs a lot since they have a minimum charge.
    We decided to spend an extra 2k to have the gunite crew come back and fill it in. Well worth it.
    Phoenix, AZ
    Unknown pool size -Diving pool
    Round Rock, TX
    529
    I believe that my pool has the same depths you specified. We also have a quarter turn slide that puts you in the center of the pool. It is a lot of fun for all ages!
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Apr 2010
    Buckeye, AZ 85326
    619
    We went with 3', 4' & 5' for our depths. The pool is still under construction but we modeled it after a friends pool as far as the depths go. 5' is deep enough for the kids to jump off the water feature and the rest of the pool is shallow enough to just hang out in and shoot some hoops.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Thanks for all the replys. Yes my pool is called a sports pool not a play pool. My fault. It looks like we are getting a 3.5x5x4.5. they said we should go 3.5 due to the drastic drop since we did tanning ledge instead of beach entry. My wife wanted this and we have 2 younger kids. I was really worried since we never had a pool and was afraid it may be to shallow. But it looks like we made the right call with all the responses.
    Apr 2010
    Buckeye, AZ 85326
    619
    Is you r pool under construction? Any pics?
    2' Powerfall
    I am having a hard time figuring out how to upload an image off my computer. I tried through the add file but the image is to large. I will play with it later to figure it out. I am only on day 2. We have the pool dug. All Rebar in and right now they are running the electrical and plumbing. Gunite should happen Thursday or Friday.
    Columbus Ohio
    178
    You can go to photobucket and create a free account and post the pictures on there... They have a sharing tab and then it gives you an image link for forums... Just copy and past into the posting from that! Good luck on your pool building days! I bet your counting down the days til the water is delievered!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    thanks for the reply. For the life of me I couldnt get it to work now I got it. I will add more pictures throught the day. We are a lot further along than this picture now. Today they are doing the coping of flagstone and waterfall.
