Thread: CYA and backwashing
    CYA and backwashing
    Stupid question.. I am using the sock method.. 1.75lbs of CYA at a time.. do you wait a week to backwash AFTER all of the CYA has dissolved, or do you just not backwash the week it is dissolving, or both?
    I had zero CYA in my pool and have added 3.5lbs over the last two week and I am still only barely reading 5-10.
    Thanks!
    2003 Marquis Euphoria - 400gal
    Feb 2008
    Denton, TX
    5,061
    Re: CYA and backwashing
    I would wait to backwash at least 3 or 4 days after adding CYA. A week to be totally sure. How often are you backwashing? Are you clearing a green pool and having to do it frequently because of this?
    3.5 lbs of CYA would really only get you to about 17 ppm. Should be higher than 5 to 10 unless you lost some.
    Butterfly's Avatar
    South Carolina
    10,045
    Are you using the sock method in the skimmer or in front of the return?
    If in the the skimmer, I'd wait as 257 said.
    If in front of the return, you should be able to backwash when needed with little CYA loss.
    You're done SLAMing when:
    I am using the sock method in the skimmer.. I was only backwashing because my filter gets dirty after brushing and running the polaris.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Trying tieing it off in front of the return - go ahead and add another couple of pounds.
    will do thanks!
