Results 1 to 9 of 9
Thread: Replace 1 spd 1Hp Superpumb with a 2 Speed Motor?
    Jun 2007
    NC
    255
    I'm sure this question has been asked a lot, but I didn't see it when I searched...
    Can I replace a single-speed Hayward Superpump motor with a 2-speed motor and still retain the pumping effectivity of the wet-end?
    If so, what motor (56J frame?) is the better motor to go to?
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    South Central NJ
    3,192
    Re: Replace 1 spd 1Hp Superpumb with a 2 Speed Motor?
    Do you have 230VAC for the pump?
    Scott
    Owner of - PoolGuyNJ LLC
    Jun 2007
    NC
    255
    Quote Originally Posted by PoolGuyNJ
    Scott
    Definitely YES!
    I have 230/1 phase/40 amps available!
    Triad Region of NC
    South Central NJ
    3,192
    56Y - 1081
    Threaded shaft, 56 Frame
    AO Smith CBX2102 1 HP / 1/8 HP
    or Century B034 1.5 HP / 1/5 HP
    mas985's Avatar
    Pleasanton, CA
    11,737
    Superpumps use a 56J frame like these:
    http://www.electricmotorwarehouse.com/56Jframe.htm
    You will want a 3/4 full rated or 1 HP uprated motor.
    Mark
    Jun 2007
    NC
    255
    Quote Originally Posted by mas985
    Mark:
    Is there *any* chance of putting a variable speed motor on the existing wet-end?
    My "guess" is that the speed control feature of the variable speed motors is built into the entire pump therefore I'd have to change out the entire pump. Is this correct?
    -Thanks again!
    Triad Region of NC
    Some motors can be retrofitted with a variable frequency drive to get variable speed operation. This isn't done very often so I don't really know the details. You might want to take a look at http://www.hybridpumps.com/.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can use a retrofit solution as Jason showed but you have to make sure that the motor is inverter rated. Not all pool pump motors are rated for VFDs so they will tend to fail sooner. The folks at Hybrid should be able to help you find a motor to use with their retrofit.
    However, it might be more cost effective over the long run to just go with one of their pumps. By the time you replace the motor and get the drive, you will probably be more than half way toward the full pump. The full pump offers a bit more efficiency as well so pay back would likely be only a little bit longer than the retrofit solution.
    Mark
    Jun 2007
    NC
    255
    Mark: "You can use a retrofit solution as Jason showed but you have to make sure that the motor is inverter rated. Not all pool pump motors are rated for VFDs so they will tend to fail sooner. The folks at Hybrid should be able to help you find a motor to use with their retrofit.
    However, it might be more cost effective over the long run to just go with one of their pumps. By the time you replace the motor and get the drive, you will probably be more than half way toward the full pump. The full pump offers a bit more efficiency as well so pay back would likely be only a little bit longer than the retrofit solution."
    Thanks for the information!
    It's another one of those situations where I'd like to be able to get some use out of the wet end that I already have without spending a fortune for a new pump. It seems like a 2 speed motor would be the most cost effective method, but I'll have to come up with some sources and run the numbers. I just know that I can probably (?) replace the motor and have it paid for this year... A full variable speed pump may be different.
    Thanks again!
    -Terry in NC
    Triad Region of NC
