Results 1 to 8 of 8
Thread: Cloudy pool
    Cloudy pool
    Hello all,
    I am a noob to the pool. Bought a house that has been empty for over 2 years and the pool started out as swampy mess.
    I have managed to get the water a cloudy blue and particles floating in the water and heavier things slowly sinking to the bottom.
    I was initially running the pump approx 18hrs a day, shutting off to allow stuff to settle, vacuum, repeat. Now I have been running it 24/7 the last couple days and of course cleaning as needed.
    My numbers are decent (when compared to the TFP recs) and I will post today's results later on.
    Should I be doing anything more or just continue my filtering, brushing, and vacuuming and maintaining chem levels?
    Thanks
    15000 Gallon AG Vinyl
    Cartridge
    1.5 HP pump
    Pontiac, IL
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: Cloudy pool
    No the best thing that I've learned while cleaning is to have patience. Bleach, brush, settle, vacuum.
    It of course is hard to guide you in the right direction with your chemistry without numbers.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Re: Cloudy pool
    As long as the water is improving day by day, then just keep doing what you are doing now. If you feel like the water isn't getting even a little bit better each day then there are some things you should check on. From what you wrote, it sounds like everything is moving along normally.
    Re: Cloudy pool
    Here are numbers from a couple of days ago. Next testing will be done today
    CYA 35
    TC 10
    FC 8
    PH 7.9
    TA 202
    TH 181
    Added acid to adjust pH and TA
    Cartridge
    1.5 HP pump
    Pontiac, IL
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: Cloudy pool
    So is your CC-2?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy pool
    Having TC 10 and FC 8, you have CC of 2 which means that you need to shock your pool.
    You can read How to Shock Your Pool in Pool School. If you have any questions, just post back.
    Welcome to the forum
    You're done SLAMing when:
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: Cloudy pool
    Yeah def need to shock if your cc is in fact 2.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy pool
    Sounds like you have a handle on things.
    What are you testing with?
