Thread: Chlorine vs. Bleach
    Chlorine vs. Bleach
    First off, I feel fortunate to stumble across this site after dumping $$$ at a local pool store for chemicals
    Now, I am stuck on the math of Big R liquid "pool shock" (10% chlorine) vs walmart bleach (6%). The shock goes for $2.25/gallon and the bleach for $1.79/gallon or $2.54/1.42 gallon. If I am guestimating correctly, I would need 5 gallons of bleach to match what would be in 3 gallons of the shock (is this correct thinking?). Therefore, it would cost me $6.50 for shock and $8.96 for an equivalent amount of chlorine in bleach form.
    Please correct me if wrong!!!
    Thanks
    15000 Gallon AG Vinyl
    Cartridge
    1.5 HP pump
    Pontiac, IL
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: Chlorine vs. Bleach
    Check out the pool calculator on this site it is very helpful in figuring out what you need for chlorine.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by npholt1
    Thanks
    Exactly, 3 gallons of 10% equals 5 gallons of 6%. Clearly where you are, the 10% is the better deal.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that most bleach is sold in either 3/4 gallons or 1-1/2 gallon containers and not in 1 gallon containers.
    Quote Originally Posted by chem geek
    Exactly, note that I mentioned what is above in the OP. Breakdown came 1.4 cents per fl oz for bleach and 1.7 cents for chlorine.
    Cartridge
    1.5 HP pump
    Pontiac, IL
