Thread: ??'s re: installing beaded liner
    We have a beaded liner. To replace it, does the top metal piece that goes around the top of the pool have to be removed? Is it a do-it-yourself project or something that really needs to be done by a pro?
    Thanks!
    27' AG round pool; vinyl liner; 1 HP pump; 40 GPM Tagleus sand filter
    22,551
    Re: ??'s re: installing beaded liner
    On a beaded liner pool the bead channel stays in place when replacing the liner. Provided you're pretty handy, it's a do-it-yourself job. The trick is to take your time and make sure everything is perfect as you go.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    That is correct, you will NOT have to remove the rail or caps to replace a beaded liner. They are pre-measured and "fitted" to your pool so they are meant to hang in the space correctly, vs an overlap that you rely more on hanging over sides and stretching in for the fit. Mind you it will still need to "stretch" in somewhat so do not try to install it on a cold or cloudy day - sunny and warm is best for all liner replacements so that the vinyl will more easily stretch into the remaining spaces. Good luck and hoping you have sunny days.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    South Central NJ
    3,192
    Make sure you buy a liner with the correct wall height! They come either 48" or 52" heights.
    Scott
    Owner of - PoolGuyNJ LLC
