Thread: solar heater question
    If I pick up some used solar panels from different sources, can I put together ones from different manufacturers?
    18x33 above ground pool, vinyl liner, starbright DE filter, 1.5 HP Dynamo pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: solar heater question
    Possibly. Depends on a lot of things like the size of the panels and headers and what flow they are designed for. Biggest problem might be balancing flow if they are significantly different.
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    There has to be a way to do this. I would try to plumb them in parallel. Don't have the same water go through both heaters. That could be too much resistance.
    12' x 20' Intex Oval Frame Pool, AG
    Waterway 1 hp TWM Cartridge Filter
    4' x 20' solar panel
    41' water depth
    4393 Gallons according to the box.
