Thread: Stabilizer?
    Apr 2010
    Syracuse, NY
    103
    Stabilizer?
    Is stabilizer ppm dependent on chlorine level? In other words, will stabilizer test low if there is a lot of chlorine in the pool? Right now there is a LOT (5ppm+) of free chlorine in in the pool after opening. I tested the stabilizer level and it was low. I added 4 lbs (1 lb/5k gal) of stabilizer (CYA) and today, after it is all dissolved and circulated the reading is still low. Should I add more stabilizer or wait a while?? Thanks.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Stabilizer?
    It can take several days to a week for stabilizer to dissolve and circulate. Don't add more unless you are sure you need it. The test is not affected by the chlorine level.
    Apr 2010
    Syracuse, NY
    103
    Re: Stabilizer?
    Great. Thanks.
