Results 1 to 16 of 16
Thread: Water dribbling from backwash port!
    Apr 2010
    Syracuse, NY
    103
    This is our first year with an inground pool. We have a 9 year old, Jacuzzi 250L Sand Filter w/Cygnet 1hp motor and pump. Yesterday I noticed a small stream of water coming from the backwash port while the filter is in 'filter' mode. I don't think this is normal. It's more than a drip...it's a small steady stream. Any help is much appreciated. Thanks in advance.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Aug 2009
    North Central Texas
    1,358
    Re: Water dribbling from backwash port!
    Welcome to TFP.
    What kind of backwash valve do you have? That will help others to troubleshoot with you.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Apr 2010
    Syracuse, NY
    103
    Not sure what you mean. This is all new to me. The top of the filter has a 7 position handle that spins a diverter inside the cover. "Backwash" is one of the 7 positions, and the backwash water exits the top of the filter from a separate opening that is 90 degrees from the normal return to the pool when the filter is in the nornal "filter" position.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,127
    Most likely you need to replace your multiport gasket. Fairly cheap and not a big job. Get your valve part number and go to a pool store or look online.
    Apr 2010
    Syracuse, NY
    103
    There is a rubber square ring gasket in the valve body. I'm assuming that this is the one you are talking about? Thanks.
    SW Indiana
    9,127
    Quote Originally Posted by edweather
    Without knowing what brand of filter you have, I can't be sure, but you are looking for something like this:
    Mar 2007
    Coastalish 'down easter'
    4,160
    I gotta agree with John, the spider gasket/ wagon wheel is the probable cause.
    The one John shows looks like a Hayward SP 710XD, which will fit a Hayward multiport with 1.5" ports.
    As long as you're in there, make sure the channels it fits in are not broken
    Please keep us posted, especially with the multiport model #.
    (As a quick and dirty fix: plug the backwash port so you're not loosing water )
    Luv& Luk
    -Ted
    Apr 2010
    Syracuse, NY
    103
    OK, the multiport is a Jacuzzi #39263009. I can't find much online with that # at all, but I've found #39262803 which looks like the same thing. From what I hear, Jacuzzi stuff is getting harder to find. I haven't found a diverter (spider) gasket online, but I found a repair kit for the 39262803 which has the diverter and gasket & some other stuff, for about $50. I'm going to check around locally tomorrow. Before I do any of this, I should probably look at the existing gasket and maybe get a part # off of it. We have 4 good pool places in the Syracuse area. Thanks. I'll keep you posted. Update: Found a lot of sites to buy spider gaskets, but none are an easy match for mine....I need to take a good look at mine first and go from there....to be continued.
    Apr 2010
    Syracuse, NY
    103
    OK....UPDATE.....Good news and bad news. The good news is that I found the gasket. The only way to buy it is with the diverter, and it's pre-installed and can't be removed. I'm ok with that. The bad news is that I can't figure out how to get the existing handle/cover/spring/diverter apart. The handle looks rivited on and I can't see any other way to take it apart. There must be a way. I've sent emails to the two places I'm in contact with to see if the repair kits come with instructions. Help please. Thanks
    Apr 2010
    Syracuse, NY
    103
    I figured it out. The rivet on the handle, is NOT a rivet. It's a pin, and it taps out. The gasket is definitely worn. I checked it out. I let you know when it's fixed, with the part #.
    22,398
    Glad you figured out it was a roll pin.
    Apr 2010
    Syracuse, NY
    103
    Job done! I was fortunate. The local pool place, Tarson Pools, who built our pool, took apart a new valve they had and sold me the diverter w/gasket out if it. They charged me $31, and they saved me from having to buy a diverter rebuild kit for $50-$60. The Jacuzzi part # for the 6/7 way dial valve diverter repair kit is 39251509K. It took me about 20min. to install it and now the dial valve works like a charm......smooth as silk, w/no leak from the backwash port. Before the repair the dial valve was really hard to turn...not now.
    I can not tell you how much this site and in particular this topic has helped resolve my problem. I was given a 18x33 oval pool 6 months ago, there was no way i could have afforded one myself. For the last 12 years, without fail, i have had a pool for my kids. As they get older i would move up to the next size, so i wasnt a complete idiot servicing and maintaining a pool. However, this GIGANTIC pool has been a challenge from the get go. I won't bore you on all the details but besides the problem with water leaking ( would spend 15 minutes after each backwash resetting and resetting just to get a acceptable dribble)from backwash, in the last week it was getting near to impossible to turn the valve. So after hours of reading, research and more reading, I read this post and well rolled up my sleves.....So here I am a half hour later not only is my handle turning smoothly,,,,, I now no longer have ANY leak out backwash. Its amazing what a little vaseline (gasket)and some cleaning (carborator cleaner around spring and under handle) will do. But mostly your info and directions is what got the job done.....Thanx guys(girls), I needed something to finally go smoothly with this pool!!!!!! Now back out to the pool to deal with this algae, Lord knows I've put enough shock n sock in it to clean all of ocala
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Welcome to TFP
    If you read through pool school, post a full set of test results...we can help you battle that algae. I'd prefer to see you using liquid chlorine to shock as the shock product your are using may over elevate your CH level and possibly cause cloudiness and calcium scaling.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Thanks edweather. This post is a help to me as I have one of these repair kits on the way to fix this same problem. I'm a little nervous about trying to remove the pin but hopefully it won't be too bad.
    Thanks again!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Jul 2011
    Huntsville, AL
    96
    I need the spider gasket for my 250L. How do I get it out of the diverter? I have a steady stream of water coming out of my backwash port. I'm confused. If I buy the 39251509K will I be able to get the spider gasket out of it and replace the broken one on my 250L multiport.
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
