Results 1 to 7 of 7
Thread: Help with Green Swamp
    I started over a week ago with a Green Swamp. When I first shocked the pool, the water turned Milky Blue (cloudy) and has remained ever since. I can only see approx. 2-3 inches below surface.
    I have been keep the pool water at shock levels daily, pump has been running 24/7 on high. The last 3 days, I have been brushing and vacuuming. When I brush, I do see clouds come to the surface in certain areas of the pool and when I vacuum I am getting up leaves.
    Besides continuing to monitor my chemistry levels, can I do anything else? Add DE to filter (new sand filter put in place last year)?
    Right now, my chemistry levels are:
    FC--17
    CC--.5
    PH--7.3
    TA--130
    CH--100
    CYA--38-40
    Pool is 24 ft AGP with approx. 14K gallons. I am using Sand filter.
    Thanks
    JB
    30,419
    Re: Help with Green Swamp
    The single most important thing I can recommend is to keep vacuuming and brushing. It will be difficult to get the pool sparkling as long as there is debris on the bottom or dust/dirt suspended in the water.
    Your test results all look fine. Keep them there and remember to replenish the FC often.
    I think if you will just do more brushing and more vacuuming, the pool will begin to show some changes pretty quickly. I assume you are running your pump 24/7 and backwashing/cleaning your filter as needed.
    Jan 2009
    Cupertino, CA
    1,966
    Hear hear on Dave's advice. Remember that a sand filter is actually a little more effective when it is slightly dirty, so don't backwash too soon; wait until you see the PSI go up a noticeable amount, like by 6-8.
    --paulr
    BBB "Intermediate Swimmer"
    So I have been checking my levels every couple hours and adding bleach to keep above FC > 15. The pool seems to be clearing a bit. I can see a little more of the latter. I have also been adding a bit of DE hoping to filter out faster.
    This afternoon, I checked the pool temp and it was 80 degrees. Therefore, since my pool is circular, I got in the pool and went round and round creating a whirl pool. I cut the pump off, let everything settle in the middle and I vacuumed to waste. I emptied 3 skimmer fulls of junk from the pool.
    I just replaced the displaced water, checked the levels, adjusted FC, and will check one more time before I go to bed. I really hope this helps.
    JB
    Jan 2009
    Cupertino, CA
    1,966
    Wow, clever! Sounds like it really should help get the gunk out. Not a miracle cure, but should speed up the process by some days.
    --paulr
    After approx 3-4 weeks I can finally see the bottom of my pool. Probably only have 1-2 days left and it will be sparkling. Lost count of the amount of bleach I used but proud I did not pay the pool store a dime except for a little DE.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by jbdial1515
    Yes, that's a good feeling!
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
