Results 1 to 11 of 11
Thread: Never ending dirt battle.
    Aug 2009
    Arizona
    10
    We live in the desert, and I live near farms. My pool seems to alwasy have dirt in it. I turn the pump on, brush all the dirt to the main drain, and the dirt stirs up in the pool. After I let it sit a minute it seems that the dirt goes back to right where it started. Spread out all over the pool. I can brush this thing all day long, and it doesn't seem like the dirt goes away.
    What am I doing wrong?
    Thanks
    11,028 ga. | IG Plaster:Blue Haven Quartz | Jandy 4 Cartridge Pool Filter:CL460;150gpm. | Paramount in-floor system:Pv3. | SmartPure Ozone Generator:SPP70 | Helio-Matic Solar Pool Heater:HM4000c
    30,421
    Re: Never ending dirt battle.
    Can you confirm it's dirt or is there a possibility it might be dead algae?
    A set of test results will help us get started in analyzing your problem.
    Do you vacuum?
    Feb 2008
    Denton, TX
    5,061
    What duraleigh said.
    I see that you have an infloor system but I guess that isn't handling it. Once we prove that it isn't algae, you might need to look at a robot or some type of active cleaner.
    Aug 2009
    Arizona
    10
    It very well may be dead algae. My pool was very swampy two weeks ago and have taken it from green back to blue, this dirt/algae is my last problem.
    It was terribad about two weeks ago. I left my pump on for the whole week, adding 5lbs of shock, some muratic acid, and some Algatec.
    It cleaned up very clear. My water is at:
    FC 4
    CC 0
    pH 7.4
    TA 80
    CYA 60
    I don't vaccuum because every time I hook it up, it never sucks anything up. I haven't figured out why.
    30,421
    Yikes!!! Regardless of what the substance turns out to be, your infloor is likely not capable to keep your pool completely clean. I think you will have to vacuum some.
    Aug 2009
    Arizona
    10
    So basically there is too much junk in there to brush clean?
    30,421
    My experience is restricted to just what is reported on the forum, but it seems like in-floor systems just cant get everything picked up.
    I don't know how much junk you have on the floor but I think manually vacuuming is going to be an occaisional thing to keep your pool sparkling.
    Aug 2009
    Arizona
    10
    Sounds good. I guess I better figure out why the vacuum doesn't suck. :-/
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by ccirish
    Thanks!
    A couple of common reasons for vacuum problems:
    You have to fill the hose with water before hooking it up to the skimmer.
    You may need to partially close the main drain valve or a second skimmer to get enough flow to the skimmer you are using.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Are you priming the vac hose?
    Aug 2009
    Arizona
    10
    Turned out I wasn't priming the hose well enough. I fill it with the garden hose now. I also figured out that if I leave the main drain cracked a lil it vets better results for some reason.
    Got all the algae out and have a crystal pool again. Thanks!
