Results 1 to 7 of 7
Thread: kenmars Pool Opening 4/30/2010
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi All,
    Our pool was opened today!
    Initial Readings
    FC: 0
    CC: 0 (this confuses me, but I am OK with it)
    CYA: 20
    PH: 7.2
    TA: 20
    Water Clarity: Dull, with visible algae on walls and floor. Main drains were visible.
    Added bleach and trichlor tabs(to bring up CYA.)
    FC was 18 two hours later.
    Spent 2 hours brushing and vacuming.
    Gave the Dolphin Dynamic a workout.
    And this is what I get Woot Woot!
    I'll work on the CYA and TA over the next few days.
    Thanks Trouble Free Pool!
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: kenmars Pool Opening 4/30/2010
    Where's the visible algae?
    I suggest you get that TA up this evening or tomorrow morning - use baking soda. Target 70 and add half the calculated dose. Let it circulate about 2 hours and test it again, recalculate and add more to reach your target. Test the PH again.
    Why does the CC confuse you?
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    With a green pool and 0 FC, I would assume CC would register greater then 0.
    I will work on the TA/PH tomorrow.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    If the fc had been 0 for some time, there was no fc to combine with anything and make cc! so zero makes sense there. Looks like you had a TFP opening!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    11,969
    So it was blue when you opened it, and now it's this dark teal green? Odd.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    I am not sure if you were kidding or not, but it was green at 11AM when I opened it, and now it is blue.
    I posted the green picture to show what it looked like when I opened it (compared to how it looked a few hours later.)
    11,969
    Ok, I clearly was confused, LOL
    Thanks for setting me straight
