Thread: New AG Pool Going in Next week, Deliberating on Baqua/Chlori
    I'm getting a new AG Pool put in next week or so, I've done alot of homework and think I'm ready for it. I have a 450 gall Hot tub now that I switched to Baquaspa about a year or so ago from bromine... and don't mind it in the hot tub, no issues yet.
    so of course my pool store in town is suggesting I stay with a Baqua product for the new pool since there will be some interaction between the tub and pool and he said it may throw off my chemicals in one or both? is this true? suggestions? comments.
    From reading everything, I know I'll probably be swayed to go Chlorine in the pool but then do I have go back to Chlorine or Bromine in the Hot tub?
    I appreciate your suggestions, advice..
    anxiously awaiting
    Attached is a mock up for what my new pool set up will look like , will be adding onto the back of the deck to have a raised deck around the pool edge.(ignore the railing on pool side)
    AG 21' Pool with Sand filter and 1500GPH Pump
    Also have Marquis Spa Hot Tub built into deck.
    Want a Cool Restored Vintage Soda Machine for your Pool Deck for Pop , Beer and Drinks...
    Visit me at www.popmachineshop.com
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New AG Pool Going in Next week, Deliberating on Baqua/Chlori
    Cool renderings.
    Avoid Baqua - it will cost you a fortune and former Baq users can attest they should have switched sooner. Read all the Baq horror stories in the Baq forum. Chlorine in a spa is easy and simple - and cheap. I wouldn't let the spa sway you - just switch it to chlorine.
    How to Use Chlorine in a Spa
    Personally, I'd ask exactly what interaction there will be between the pool and the spa. They're on separate plumbing, right? The spa's a couple inches or more above ground level?
    For there to be interaction, I would expect:
    A) water from backwashing a sand filter is going to go along the ground and be high enough to flood your spa (no more likely than heavy rainstorms doing so, I would expect)
    B) Your pool is going to overflow on the raised deck side, and tens of gallons or more is going to make it along the planks of the deck, down the stairs, along the planks of the deck, and into the spa without managing to fall to the ground
    C) Swimmers are going to carry tens of gallons from the pool to the spa in their clothing, or hundreds of gallons from the spa to the pool.
    D) Just like B, but flowing up the stairs from the spa to the pools with hundreds of gallons making it into the pool
    E) something else
    P.S. Tens of gallons and hundreds of gallons is an unscientific off the cuff guess of what it might take to produce a difference in your hundreds of gallons of spa water that you can measure with your test kits.
    13,500 gallon, 24' round vinyl AG pool, fully encircled by deck. Hayward pump, DE filter, and chlorinator (use is being discontinued), one skimmer, one main drain. Polaris 65.
    I think they were just referring to users going from pool to spa or vice versa.. I personally didn't think this small amount of wet suites would cause a problem with either chemical, since the pool will have aroudn 12,000 gallons I think and the spa is 450 gallons..
    I"m sure they are just swaying me to one product... I'm going to one of their pool trainings this thursday night and will see what they say , although after reading all the negative posts about baquacil ... I think my mind is made up?
    John
    South Central NJ
    3,192
    Baquacil is still a fairly tightly controlled distribution. This tends to raise costs because there are fewer available suppliers.
    Baqucil tends to cake up DE and sand filter and clog cartridge filters faster than a chlorine pool will. This is another cost burden.
    Baquacil uses highly concentrated Hydrogen Peroxide for shock. You must wear gloves when adding it or it will burn.
    After a few years, problems like red algae pop up.
    Scott
    Owner of - PoolGuyNJ LLC
