Results 1 to 7 of 7
Thread: Low TA
    Low TA
    just wondering.
    My TA has been around 50 for the past 6 month. Any harm keeping TA 40-50 level???
    BTW. My PH still goes up every week (7.8+) and need to add one gallan of Acid to get it down to 7.4 level.
    25,000gal Inground Plaster Pool
    Pentair WhisperFlo WFE-6 1.5HP X 3
    Pentair Clear and Clear Plus Cartridge 420
    Pentair MasterTemp 300,000 btu Heater
    Compu-Chlor Super Salt System
    22,544
    Re: Low TA
    That seems a little low for a plaster pool but we really can't tell for sure without knowing what the rest of your numbers look like. Can you post a full set of test results?
    pH =
    FC =
    CC =
    TA = 50
    CH =
    CYA =
    Re: Low TA
    pH = 7.8
    FC = 7
    CC = 0
    TA = 50
    CH = 350
    CYA = 50 (using some left over shock to bring this up to 70)
    Also, I'm running SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Low TA
    How old is the pool surface?
    Re: Low TA
    the pool is about 4 years old.
    11,969
    Re: Low TA
    I would suggest this - Use baking soda to get the TA to 60-70. Allow it to circulate. Raise your CYA as you planned, that can be done in any order, and use the sock method- the TA can be added while the CYA is dissolving. After several hours retest the PH and TA again, see where the TA ends up. Then I'd adjust the PH down to 7.2 with Muratic Acid.
    Once the CYA is up, see if you dial down your SWG run time a bit, to see if you can reduce the PH from drifting up. How often are you running the SWG now?(what % )
    Re: Low TA
    thank you poolmom - will give that a try!!
