Results 1 to 13 of 13
Thread: A stretegy for starting with very basic water
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    Happy Spring,
    I will be filling my pool again soon, so I am getting a fresh start on my water. With the advice of TFP I have been having progressively better results putting less in it each year. Visitors have commented on my pool water being very nice.
    My tap water has a TA of 30. Best I can tell my tap water has a pH of 9.6. To measure this I mixed 2 parts of pH 7.2 distilled water with one part of my tap water. This tests as pH 8.
    Assuming pH's average each other I computed my tap water pH as follows.
    ( pH + 7.2 + 7.2 )/3 = 8
    pH + 14.4 + = 8 * 3
    pH = 24 - 14.4 = 9.6
    Adding the 72 ounces of baking soda to get my TA to 100 will probably add another 0.15 to the pH.
    Adding the 23 ounces of CYA will probably drop the pH 0.75.
    Last year I added muriatic acid to bring the pH down right away, but I wonder if I should bother at first. My water will drift more acidic over time.
    What I am thinking of doing is adding the baking soda and CYA, maintain a fairly high chlorine level of about 8, but not worry about the high pH until the water is warm enough to swim in. With only 4.4k gallons of cold water the bleach bill will be very low.
    When the temperature get to swimming temperature, about 67F, adjust the pH to 7.4.
    Is this a good idea, or should I adjust the pH right away with the muriatic acid? One good point of dropping the pH now is I would be adding borax sooner and getting some borate in there.
    12' x 20' Intex Oval Frame Pool, AG
    Waterway 1 hp TWM Cartridge Filter
    4' x 20' solar panel
    41' water depth
    4393 Gallons according to the box.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: A stretegy for starting with very basic water
    Very simply add the water, let it circulate for several hours - and then test and go from there. Raise the TA first to 90-100 and allow that to circulate for and hour and retest both PH and TA. Then use the acid and target 7.4 on the PH. Let that circulate for an hour and retest again. I wouldn't wait to adjust these things and it doesn't take that long to make the adjustments.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    pH doesn't average. If my rusty chemistry is correct, your water probably has a pH about 8.2. pH is the log of the hydrogen concentration of the solution, and is therefore not linear so the dilution method doesn't work.
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    At breakfast my wife told me she has a pH test kit for her fish tank that goes much higher. That test says the pH is greater than 8.6.
    There is something about adding muriatic acid that bugs me, but I will get over it.
    Thanks, JLM
    41' water depth
    22,553
    While I advocate muratic acid as the pH lowering chem of choice we all have our monsters and if using it bothers you, you can use dry acid (sodium bisulfate) to lower your pH. Pool Calc even lists it. It does add a little sulfates to your pool but it works without having to handle liquid acid.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Acid Magic is another alternative to muriatic acid. It is essentially muriatic acid but it doesn't fume.
    Jan 2009
    Cupertino, CA
    1,966
    Last time I bought muriatic at Home Depot, it was 15% instead of the more usual 30% and didn't fume.
    --paulr
    BBB "Intermediate Swimmer"
    SW Indiana
    9,199
    Quote Originally Posted by JohnT
    I didn't notice you had done a 2:1 dilution. The above calc is for a 1:1 dilution. For 2:1, it looks like your actual pH is 8.45. I'd let some sit in a glass for a few hours and see what the pH is after that.
    If anybody can comment on the accuracy of my method, I used log(((10^7.2) + (10^7.2) + (10^x))/3)=pH, or the log of 1/3 of the sum of 10^pH of distilled plus 10^pH of distilled plus 10^pH of unknown. If I recall correctly, and it's been a long time, you add the total number of H+ atoms for the components to do the calculation.
    Jan 2009
    Cupertino, CA
    1,966
    According to wikipedia it's not the actual number of ions, but still it's a logarithmic scale and your formula looks okay to this long-ago math major. I didn't check your arithmetic, though; it's too early in the morning out here.
    --paulr
    Mar 2007
    San Rafael, CA USA
    12,082
    Your formula is only correct due to a combination of errors that cancel each other out. Remember that pH=-log([H+]) or [H+]=10-pH, so the correct formula would have negatives in the exponents and on the logarithm, but this would only be correct when there is a significant excess of hydrogen ions to hydroxyl ions; that is, when the pH is significantly below 7.0, but that is not this situation. When there is a significant excess of hydroxyl ions to hydrogen ions then you add hydroxyl ions, 10(pH-14), instead of hydrogen ions, 10-pH. When the pH is closer to 7.0, then you can add both hydrogen ions and hydroxyl ions together separately, but then need to adjust to eliminate enough in pairs (to produce water) until you get to [H+]*[OH-] = 10-14.
    There are also pH buffers in the water and normally that makes the computation much more complex if acid or base were added, but when adding distilled water this is a pure dilution effect so doing the simple calculation of cutting down hydroxyl ion to 1/3rd of its original value is sufficient. So the pH drops by log10(1/3) = 0.48 or about 0.5 units. Therefore, a diluted reading of 8.0 means an original reading of about 8.5. I'm ignoring the 7.2 of the distilled water and treating it as 7.0. Interestingly, your calculation seemed to work, but perhaps that just works out due to the double error canceling out (i.e. no negative on the exponents nor on the logarithm and not using hydroxyl ion so 14-pH).
    Richard
    SW Indiana
    9,199
    Quote Originally Posted by chem geek
    I knew the negaitives cancelled. I'm so used to working with logs (RF Power) that I just skipped ahead to the answer I knew I was going to get I also knew the answer was pretty well impossible if you started considering the other components you would be adding in tap water.
    I'm curious why distilled water would have a pH of 7.2 though. Any insight?
    Mar 2007
    San Rafael, CA USA
    12,082
    No idea except perhaps testing error. There is some temperature dependence on the pH of pure water, but to have a pH of 7.2 the water would need to be around 56-57ºF which I suppose could happen with tap water though that seems a bit cool. Certainly possible, especially if the pH were really more like 7.1 instead of 7.2.
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    The distilled water was in my basement which is about 57 F.
    I think I will follow the advise to adjust the TA right away. I will also get some Chlorine in there right away.
    41' water depth
